| | #21 |
| Senior Moderator Supreme Forum King | You got it right. Most routers have so much torque it is difficult to work on a narrow edge. By adding more support to the outside of the "case" you eliminate a great deal of the wobble effect. The large base plate that straddles the cabinet width is a good fix too. Perhaps the first obstacle beginning routers have to overcome is the tendency to tilt the router while working on an edge. Adding an extra board for support while edge routing greatly improves results.
__________________ Mike |
| | #22 |
| Forum Contributer Supreme Forum King | Hi Guys Here's a little tip for routing PLYWOOD and Veneer plywood on the router table... Run the stock by the bit in the climb way, that's to say backwards from the norm.. But this should only be done 1/4" deep max for each pass... This will hold/push the chips/saw dust into the slot and hold plywood in place when the bit goes by the slot unlike the normal way when the bit pulls the chips/saw dust out of the cut... Do this for a quick test, cut some scrap plywood up , say 6" wide and about 18" long, run it by the bit the right way then flip it around and pass it by the bit in the climb cut way,,you will see the climb is clean with almost no rip out...this also works for dados and groove cuts.. =============
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 11-17-2007 at 08:29 PM. |
| | #23 |
| Registered User Supreme Forum King | I've seen this done a time or two... use painters tape along where the rabbit will be.
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #24 |
| Registered User New Member | Relate to the subject of routing plywood: Has anyone had success using a drawer lock bit on half inch Baltic birch? It does fine going with the grain, but creates a lot of tear out going cross grain. By cross grain I mean in relation to the top veneer. I tried scoring, using painters tape, wetting the plywood and multiple shallow cuts. The bit is of good quality and new. I tried three different bits. All the bits do well in solid wood. |
| | #25 |
| Registered User Supreme Forum King | For ply, I'd think you'd want to "score" before you make the cut. Or make "relief" cuts.
| | #26 |
| Forum Contributer Supreme Forum King | Hi Ken http://www.routerforums.com/63871-post2.html http://www.routerforums.com/63885-post3.html http://www.routerforums.com/table-mo...html#post63885 ==========
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| Dovetails In Plywood | rmaxa | Router Bits - Types and Usage | 6 | 12-19-2006 10:00 PM |
| Rabbeting 3/4" plywood edge | WoodenShoe | Table-mounted Routing | 3 | 06-13-2006 01:15 PM |
| Problem with my Hitachi M12V | Visteonguy | Table-mounted Routing | 23 | 08-18-2005 11:22 PM |
| elu router problem | fretbender | Portable Routing | 7 | 03-21-2005 10:35 PM |
| Hitachi M12V Router Problem | dcarriere | Tools and Woodworking | 3 | 12-28-2004 06:50 AM |
