| | #1 |
| Registered User Sr. Member | Hello, Thinking I had a good deal, I purchased a NIB Dewalt DW670 on eBay to use as a trim router. Unfortunately, the little beast is a single speed unit that spins at 30,000 rpm. I prefer lower speeds and, therefore, considering using an old router speed control (from either Rockler or MLCS) that I have in the shop. The DW670 isn't a soft-start unit, so the speed control should work, I think. Is there a better alternative? |
| | #2 |
| Banned Supreme Forum King | W e l c o m e . . A b o a r d !! |
| | #3 |
| Retired Moderator Supreme Forum King | Welcome to router forums. I don't know of an easier way, with a little portable router like that, I wouldn't want to be dragging around a speed control with it, having it fall off while routing or something. Be careful, if you really want a VS trim router consider getting one with VS built in. Corey
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Thrifty Tool Guy I will agree with Corey you may want to look into a Colt router.. Here's a new one at a great price,,, see link below...he has 10 for sale. http://cgi.ebay.com/BOSCH-PR20EVSK-C...QQcmdZViewItem Some of the members have got one of the Colts and they are a great 1 HP router.. ========== Quote:
| | #5 |
| Registered User Sr. Member | Thanks for your input. If I had done my homework, I would have went with the Bosch Colt. At this point, I'm trying to justify keeping the Dewalt. It will serve purely as a trim router. I primarily use two table mounted routers for real work. |
| | #6 |
| Forum Contributer Supreme Forum King | Hi TTG All I can say it's nice to have two, one for trim work and one for all the small jobs you have ,I put one in a small router table and it's a great setup... http://www.routerforums.com/45518-post1.html ===============
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-11-2007 at 07:45 PM. |
| | #7 |
| Registered User Forum Fanatic | I use a common rotary dimmer switch as a speed control on many tools with brush type motor. Don't try it on induction motors or excessive amperage loads. I installed mine in a double electrical box... dimmer on one side, duplex receptacle on the other... with a grounded pwer cord feeding the gadget. Works great on routers, drills, etc. |
| | #8 |
| Forum Contributer Supreme Forum King | Hi Roefa They make one for the router ![]() http://www.harborfreight.com/cpi/cta...emnumber=43060 The dimmer type will heat up and most are rated at 10amp or less..I also use one for a long time until it took a dump... You can tell when it's over for them when you hear a buzz coming from the dimmer... Bj ![]()
| | #9 |
| Senior Moderator Supreme Forum King | While a dimmer switch may function for a while, routerforums.com specifically recommends you do not use a dimmer switch as a speed control. Dimmer switches are not designed to handle the load. Use a UL listed or CSA approved motor speed controller.
| | #10 |
| Registered User Sr. Member | Interesting, not a single reply offering a defense of the DW670. Consider that many people have strong opinions about what they spent their money on, the DW670 must be pretty mundane. |
| Freud speed control module | pedixon | Introductions | 12 | 02-27-2008 08:26 AM |
| Blown Hitachi M12V speed control bypassed | honyacker | General Routing | 7 | 09-14-2007 10:41 PM |
| Speed Control - with a table/bench saw | Drugstore Cowboy | Tools and Woodworking | 8 | 06-11-2007 10:05 PM |
| Speed Control Switch | jfacteau | General Routing | 1 | 03-08-2007 04:39 PM |
| External speed control for Maktec | edilson | Tools and Woodworking | 1 | 10-25-2006 10:06 PM |
