| Portable Routing Discuss Modifying your signature in the Routers forums; What is a signature? I bet your asking yourself, what is a signature? A signature is... well a signature, it'... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Forum Administrator Supreme Forum King |
What is a signature? I bet your asking yourself, what is a signature? A signature is... well a signature, it's included on the bottom of each post you made without you adding it. Below is an example of a signature. ![]() Click to Enlarge The red highlighted area is were the signature appears, its included at the bottom of each post you make. You can include text, images, quotes, code etc.. in your signature. How do I setup my signature? It's actually quite simple to setup your signature. Simply click on 'User CP' which is located at the top of every page ( its on the nav bar ). If your still having troubles finding the 'User CP' you can click the link below. Click here to goto your User Control Panel Once your in your user control panel you'll see a variety of links along the left side. It should look similiar to this. ![]() Click to Enlarge Then find the link called 'Edit Signature' it should bring up another window that has a text area were you can enter the contents of your signature. Once you've entered what you want to be included in your signature just simply click the 'Save Signature' button. Your done! Did this tutorial help you?
__________________ Mark, Administrator and Technician of RouterForums.com Contact RouterForums.com Refer a friend to RouterForums.com! Last edited by Mark : 09-12-2004 at 07:46 PM. | ||
| Modifying your signature | Mark | Lobby | 4 | 01-02-2006 05:37 AM |
| Modifying your signature | Mark | General Routing | 1 | 12-20-2005 09:48 AM |
| Modifying your signature | Mark | Introductions | 0 | 09-12-2004 07:43 PM |
| Modifying your signature | Mark | Jigs and Fixtures | 0 | 09-12-2004 07:42 PM |
| Modifying your signature | Mark | Table-mounted Routing | 0 | 09-12-2004 07:42 PM |
All times are GMT -5. The time now is 04:50 PM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
