Go Back   Router Forums > Routers > Portable Routing
Rate This Thread - dado querie.
Thread Tools Display Modes
Old 12-23-2007, 02:28 PM   #1
woodfordktm
New Member
woodfordktm's Avatar
woodfordktm is on a distinguished road
Default dado querie
My first of many questions is. Can a 17mm wide dado be cut on veneered chipboard without the veneer chipping?. The boards are 600mm wide and the dado is to support the shelfs of a builtin cabinet. Any suggestions on technique would be appreciated. Cheers, Terry.
woodfordktm is offline   Top - Reply with Quote
Old 12-23-2007, 03:15 PM   #2
nzgeordie
Forum King
nzgeordie's Avatar
nzgeordie is on a distinguished road
Terry. One method I've used with success is to score the limits of the cut with a sharp craft knife before routing to prevent splintering of the surface. This is a newbie's solution and our more experienced members might have better ideas.
Pete
I've cut it twice and it's still too short! But only at one end.
nzgeordie is offline   Top - Reply with Quote
Old 12-23-2007, 04:33 PM   #3
woodfordktm
New Member
Thanks nzgeordie, I will try ur tip. Once I cut the boards to required size I will experiment with some offcutts and see what happens.
Old 12-23-2007, 04:40 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Terry
Geordie way works well but if you don't trust the cut you can do, you can do it one more way,with a veneer clamp boards(s)
PLUS
Great bit to use on veneered plywood, also the Down Spiral bit works well
It puts presser down on the veneerer or the top part of the plywood ,holding it down so to speak.
Compression Up/Down Spiral Router Bit
This 2 flute solid carbide bit is needed to get clean, chip-free and splinter-free cuts in composite sheet goods such as Melamine or 2-sided Formica/Laminates and veneered plywood.
The Up-shear/Down-shear design of the bit cuts toward the center of the sheet from both sides at once, saving time and eliminating waste.
http://www.mlcswoodworking.com/shops.../bt_solid.html
bobj3 is online now   Top - Reply with Quote
Router Table Dado Jig RoyBullets Jigs and Fixtures 11 06-16-2008 08:41 PM
Dado Jig for Plunge Router bobj3 Jigs and Fixtures 19 10-30-2006 11:57 PM
FREUD Dado Sets sawstop Tools and Woodworking 4 10-30-2006 03:57 PM
Router Adjustable Dado Jig Barry_White Jigs and Fixtures 4 02-07-2005 01:17 AM
starting dado Jens Jensen Table-mounted Routing 8 10-06-2004 09:55 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
