Go Back   Router Forums > Routers > Portable Routing
Thread Tools Display Modes
Old 01-29-2008, 07:32 AM   #1
Woodworker 52
New Member
Woodworker 52 is on a distinguished road
Question Routing a decorative edge on the inside of a faceframe?
How would you route a decorative edge on the inside of a faceframe, how do you get to the inside corners? or if you route before you glue the faceframe together how do you know where to stop to have the corners meet?
Dennis
Woodworker 52 is offline   Top - Reply with Quote
Old 01-29-2008, 09:33 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Dennis
That's a hard one to do, it's best to glue them up and then route the inside...
But if you want the look of a sharp corner ( bead) you can use stop blocks or do them on the router table with stop blocks...it's tricky setup but it can be done with care...if the frames are long you will need to make a longer fence to to hold the start and stop blocks...with some 3/4" MDF stock..
Run a tee slot down the new fence to hold the stop blocks...in that way you use it for all the parts of the face frame...
Just push the stock into the bead bit and at the end on the pass just pull it back off the fence..
It's best to cut your parts for the face frame a bit longer and wider then cut/rip them to size b/4 the glue up...
Good Luck
Dennis
Bj
Old 01-29-2008, 01:00 PM   #3
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
If you are ok with the inside corners being rounded the radius of your router bit - this is easy -- just route it after everything is in place as BJ mentioned.
If you want/need sharp square inside corners -- you are going to have some detail work to do any way you go about it.
Have never tried BJ's suggestion - but no doubt it would work fine.
Here are a few others I have tried with reasonable success -
1 - Route 'after the fact' as above - then go back with a chisel, dremel tool, carving knife or your weapon of choice and hand finish the corners.
2 - Route the decorative edge as a seperate piece then miter and attach it like commercial molding/trim. This works great if you are doing a beaded edge where there is a natural line to mask the joint.
3 - Route your edging the full length of the stock -- or at least before the final cut. Then -- with a hand saw, band saw, scroll saw, etc. carefully remove and miter your edging as needed (see sketch).
Can't say that any one is better than another -- just depends on your own work style and the tools you are comfortable with.
No doubt you will get other good answers as well.
The one who says it can't be done --
Should avoid interrupting
the person doing it.
Drugstore Cowboy is offline   Top - Reply with Quote
Routing out inside of a 3/4 x 2 x 4 DavePowers General Routing 5 04-14-2008 08:43 AM
Routing a decorative groove on an inside curve HanDan General Routing 2 03-15-2006 03:43 PM
Help on Inside Corner Routing aquarium-builder General Routing 6 01-06-2005 02:43 PM
routing a bearing edge on drum shell UNsound General Routing 2 10-24-2004 02:40 PM
Routing edge on plywood Dimitri Guest General Routing 2 10-20-2004 02:34 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
