Go Back   Router Forums > Routers > Portable Routing
Portable Routing Discussion area on the Portable Router and its applications. Bob and Rick say, "If the piece is bigger than the router then chances are it should be routed with the portable router."
Thread Tools Display Modes
Old 02-27-2005, 03:42 PM   #1
fretbender
New Member
fretbender is on a distinguished road
Default elu router problem
Hi,
I have been searching the Internet hoping to find a solution to a problem I have with an ELU 177/120 type one router. I inherited this one from my father, whom is getting a little too old to use it anymore. The problem is with the plunge release lever. It is almost impossible to operate with one hand. The spring tension is too great. I took it apart hoping to be able to do something with it but now I can’t even get it back together.
I do remember reading something years ago that ELU had come up with a spring with less tension in it. I contacted various companies and have not had any success. Any help on this subject would be greatly appreciated
Regards
Steven
fretbender is offline   Top - Reply with Quote
Old 02-27-2005, 05:38 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Steven, there may be an easy solution to your problem. With most springs you can cut a few winding's off one end of the spring, then stretch the spring out slightly. This reduces the tension a great deal. Spring steel is tough stuff so make sure you use a hardened cutter. If this spring is a flat coil perhaps try removing one circle of the spring. You can always cut more off later, but you can't put it back. This is how a gunsmith adjusts for a "hair trigger". If you are at all uncomfortable doing this yourself take it to a professional, it shouldn't cost much.
Old 02-27-2005, 10:23 PM   #3
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Originally Posted by fretbender
Hi,
Regards
Steven
How old is this tool? Older version and if it has the cam lock on the poles the spring is used to prevent the cam lock from moving while locking the router into position. Once it is lock it doesn't need the spring tension.
SO, When I used the Elu router many years ago I removed the spring with the understanding that I must make sure it didn't move and change my depth every time I locked the router in position. Once locked into position it should be fine.
Before you do anything can you provide a photo of the router around the poles.
Rick and Bob
The Router Guys
Old 02-28-2005, 06:57 PM   #4
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
try this web site, it mybe what you want.
http://www.toolshopdirect.co.uk/part...orking/routers
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 02-28-2005, 07:01 PM   #5
delroy33
Supreme Forum King
delroy33's Avatar
PARTS/LIST/ELU_WOOD_WORKING/ROUTERS
roy
Old 02-28-2005, 08:46 PM   #6
fretbender
New Member
Thanks Mr. Delroy, I have seen this site.
Bob and Rick,
The router was purchased in the late eighties or early nineties. I have attached a good picture for you reference. Maybe removing the spring will do it. I will try it. I not sure if the cam will jam enough to lock the plunge.
Steven
http://img.photobucket.com/albums/v2.../elurouter.jpg
Old 03-01-2005, 10:19 AM   #7
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Bob and Rick,
Steven
The cam should lock it just moves slightly before it locks...but check to make sure this works before trying with router bits.
Rick and Bob
The Router Guys
Old 03-21-2005, 11:35 PM   #8
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
fretbender
Try contacting DeWalt.
They took over Elu and some DeWalt routers are based on the old Elu which is still much loved.
You may be lucky and find they still stock the springs for the 177
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 8 05-22-2007 07:42 PM
