Help
Go Back   Router Forums > General Woodworking > Project Plans and How To
The making of a balloon clock
This is a discussion on The making of a balloon clock within the Project Plans and How To forums, part of the General Woodworking category; Whilst this particular clock is quite small, it's total height being 185mm [7 3/8"], the ...
Old 05-11-2009, 02:15 AM   #1 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
Default The making of a balloon clock
Report Post Report This Post!
Whilst this particular clock is quite small, it's total height being 185mm [7 3/8"], the size is determined by the diameter of the bezel. between 20 and 30mm is added to the dia. of the bezel. I have used metric measurements but there is no problem using imperial. where I have used a 30mm template guide and 10mm cutter, giving a 10mm offset, a 1 1/4" guide and 3/8" cutter giving a 7/8" offset would be quite OK. This project does not require the use of the skis but a jig/template box IS required, mine measures 300mm x 400mm but 12" X 15" is perfect. The three templates are made from 9mm [3/8"] MDF but this isn't critical. Note the mitred corners to make removal of the templates easy.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 05-11-2009, 03:04 AM   #2 (permalink)
harrysin's Avatar
Default Part two
I've never made a secret of the fact that I make many silly mistakes but over the years have become adept at finding solutions. This second part shows the first mistake and how I chose to fix it. I should mention here that the size of the American Oak was 165mm [6 1/2"] X 210mm [8 1/4"] but this isn't critical, the important criteria is that at no point must it be possible for the cutter to touch the holding devices, be these cams, wedges or pieces of scrap MDF pinned around the sides.
Harry
harrysin is offline
Old 05-11-2009, 05:08 AM   #3 (permalink)
xplorx4's Avatar
First Name: Jerry
xplorx4 is on a distinguished road
Thank you harry, I shall take some time to look this over.
You have confirmed a belief that I have that it isn't the mistakes we make, it how we recover from them that is important, and everyone makes mistakes not everyone can recover from their mistakes.
Lamentations 3:22-23
xplorx4 is offline
Old 05-11-2009, 06:37 AM   #4 (permalink)
harrysin's Avatar
Default Part three
So far so good. It's now time to rout the rear of the clock, it's the same as the front but without the hole. It isn't essential to rout the opening in the base, for one of my clocks I made a frame around the body, using lock mitre joints but of course any joints will do. The finish was intended to be red mahogany stain followed by a few coats of shellac or Danish oil however, after it looking fine on a scrap piece, it looked shocking on the clock, hence the paint finish. I'm going to see if a suitable decal is available to take away the plainness.
Harry
harrysin is offline
Old 05-11-2009, 06:56 AM   #5 (permalink)
harrysin's Avatar
Default Part four, the base
For some odd reason the photos. of making the base "went missing", found them in the camera download programme. Please let me know if shots seem out of order or don't make sense.
I do hope that at least a few members will have a go at making one of these clocks, it really is a good exercise in making templates and plunge routing.
Harry
harrysin is offline
Old 05-11-2009, 07:29 AM   #6 (permalink)
harrysin's Avatar
Default Part five to add missing shots
I think all the shots are here now, the last one is to illustrate other sizes and finishes which can be made by following these same instructions. Good luck and don't hesitate to ask if there is something that you don't quite understand.
Harry
harrysin is offline
Old 05-11-2009, 09:52 PM   #7 (permalink)
jw2170 is on a distinguished road
Excellent Harry,
I remember you sent me a diagram for the template some time ago, but these shots really put it into plain english.
jw2170 is offline
Old 05-11-2009, 10:56 PM   #8 (permalink)
Glenmore's Avatar
First Name: Glenmore
Glenmore has a spectacular aura about
Send a message via Skype™ to Glenmore
Harry you did it with this one great job. Really like the way the finish came out for you. Looks good to me. A+++ for the photo shoot.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline
Old 05-11-2009, 11:10 PM   #9 (permalink)
Barry99's Avatar
First Name: Barry
Barry99 is on a distinguished road
Excellent work Harry. Thanks for taking the time to post the step by step pics. With out the pics and instructions I would be lost. I am going to have surgey and will be unable to do woodworking 3 to 6 months. Once I am able to, I will attempt to build one.
Barry
~Is it measure twice and cut once, or cut twice and measure once?~
Barry99 is offline
Old 05-11-2009, 11:20 PM   #10 (permalink)
curiousgeorge's Avatar
First Name: George
curiousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to behold
Excellent presentation, Harry! You are a craftsman, gentleman and a scholar.
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is offline
Making a pen - Photo shoot (Very picture intensive) Bob N Woodturning and Lathes 25 03-06-2009 01:42 PM
Clock Door RustyW Guide Bushings and Templates 13 11-15-2008 07:53 AM
Modification to Apricot clock harrysin Woodturning and Lathes 4 06-03-2008 12:23 AM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
Brand new to forum harrysin Introductions 11 01-18-2007 12:46 AM
