Build my own storm/screen door project - Router Forums
post #1 of 6 (permalink) Old 10-15-2010, 03:42 PM Thread Starter
JClamp's Avatar
First Name: Jeff
I am in the process of planning to build my own wood screen/storm rear door, only because I can't find any 24 inch ones at retails/home depots, etc. Has anyone ever attempted this? If so, do you have any information on how to accomplish this? Any help would do. The door needs to be able to have both screen removal and storm glass capability. Thanks
JClamp is offline
post #2 of 6 (permalink) Old 10-15-2010, 08:21 PM
dutchman 46's Avatar
First Name: Howard
Hello Jeff! Welcome to the forum! I am of the notion that if You want to build it. Then You will! I would recommend that You look at all the hardware You can find about building a outdoors storm door. You will do better with weatherstripping made for the door, and look at how to make it safe and tight, as far as air movement. You may need to use tempered glass. That will depend on Your local building inspector, and local codes. Have fun building it, and keep Us informed, and send photographs
John 3:16
dutchman 46 is offline
post #3 of 6 (permalink) Old 10-15-2010, 09:39 PM
AxlMyk's Avatar
You want to use at least 4" wide stiles and rails. A screen door turnbuckle is also used to help keep them square. HD sells those.
50 In. Turnbuckle, Zinc - V691 at The Home Depot
AxlMyk is offline
post #4 of 6 (permalink) Old 10-15-2010, 10:12 PM
Hi JeffC
Check your RV supply house they should have a small one that should work..
I should pull up a shot of the door that go's to the back room in my shop, it's was a used storm that I cut down because I could not find a door that size, they are easy to rework, just some screws some glass and some push in rubber...1 ,2 ,3 thing..
post #5 of 6 (permalink) Old 10-17-2010, 12:46 AM
CanuckGal's Avatar
First Name: Deb
Here are a few websites that might help.
The RunnerDuck Screen Door plan, is a step by step instructions on how to build a screen door.
TrueValue.com
All-Season Storm Door Woodworking Plan
I measured, I marked, I cut.
CanuckGal is offline
post #6 of 6 (permalink) Old 10-18-2010, 04:40 PM Thread Starter
JClamp's Avatar
First Name: Jeff
Thank you dutchman 46, AxlMyk, bobj3 and CanuckGal for the informative directions toward my building door project. Will let you all know what I come up with.
JClamp is offline
Human Verification
dw735: get the dewalt folding tables or build my own? kleptic Tools and Woodworking 23 07-01-2014 07:12 AM
Build your own CNC cdndave CNC Routing 9 08-31-2010 12:20 AM
how should i build a router table ntreaster Table-mounted Routing 9 07-24-2009 03:23 PM
Ready to build the table RoyBullets Table-mounted Routing 12 06-24-2008 07:44 PM
To Buy or Build gaviaimmer Table-mounted Routing 12 12-12-2004 09:00 AM
