| This is a discussion on Mounting an Oak Park Box Jig on Non Oak Park Table within the Project Plans and How To forums, part of the General Woodworking category; Allison, your idea of using the adapter and clamp will work out fine. The angle ... |
| | LinkBack (4) | Thread Tools | Display Modes |
| | #21 (permalink) | ||
| Retired Moderator ![]() |
Allison, your idea of using the adapter and clamp will work out fine. The angle the box joint jig is mounted to the table makes no difference, only the spacing from the bit to the jigs fence matters. Your wood will ride on top of the jig so there are no problems.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #22 (permalink) | ||
You really don't need to drill if you don't want to. You just have to set it up each time you use it and that is fairly quick with the set up bars and just holding the jig in place so it can't move. Corey | ||
| | #23 (permalink) | ||
| Registered User ![]() |
Thanks for the advice and for the compliments on the table...didn't get a bad deal at a tradeshow. Allison | ||
| | #24 (permalink) | ||
Well I guess today was my lucky day. I pulled out my Oak Park 3/8" jig which has been sitting here for months so that I could install it on my Freud benchtop table. I started to fool around with blocks and clamps when I noticed that the threaded inserts in the table which are used with the Freud fence line up perfectly with the Oak Park jig! What are the chances??? The inserts are 5/16 so I enlarged the holes on the jig to match. Once I fastened the jig I had to finesse it a touch for a perfect fit. I used the same finessing tool the router guys use (a hammer). Well that was easy. Michael | ||
| | #25 (permalink) | ||
| Forum Contributor ![]() |
Hi Michael My eyes are going bad I guess I can't see the Oak-Park jig in the snapshot I know it's white but I can't see it . ![]() Bj ![]() But that's a real nice router setup. ![]()
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | ||
| | #26 (permalink) | ||
BJ, Michael is saying the jig matches up perfectly with the threaded inserts in the table top where his fence mounts.
| | #27 (permalink) | ||
Hi Mike Yep, I was giving him a bad time hahahahahahaha LOL because it didn't post a snapshot of the GREAT Oak-Park jig as well . ![]() Bj ![]()
| | #28 (permalink) | ||
Wow, is that a coincidence or what! Nice set up as well! Corey | ||
| | #29 (permalink) | |||
Seems like the biggest trick with the OP jig is to make sure and keep the wood straight, square and plumb as you run it through the cutter. Sounds like a job for a giant right-angle push block. Sometimes I get sidetracked so many times it's amazing I find my way back to what I was originally working on Michael | |||
| | #30 (permalink) | ||
Hi Michael hahahahaha "Everyone's a comedian" ![]() I do try and keep it light ![]() I use a 2" x 6" push block and I do clamp 2 at one time, front and back and the two sides. It works well most of the time, unless I'm using real hardwood, then I will drop back to one at a time, the heat build up thing. I don't want to nail a bit for a dumb box joint. ![]() Bj ![]()
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/project-plans-how/3260-mounting-oak-park-box-jig-non-oak-park-table.html | ||||
| Posted By | For | Type | Date | |
| 9,553 Free Woodworking Plans, Free Wood working Projects & Scrollsaw Patterns | This thread | Refback | 11-06-2009 10:07 PM | |
| Woodworking Discussion Forum - Box Joint Jig | This thread | Refback | 09-30-2009 05:37 PM | |
| Workshop Router Tables and Router Accessories Free Woodworking Plans and Projects | This thread | Refback | 09-11-2009 11:36 PM | |
| Router Box Joint Jig - Woodworking Talk - Woodworkers Forum | This thread | Refback | 03-20-2009 03:28 PM | |
| Oak Park Router Table | B_Rod | Starting Off | 27 | 02-20-2008 06:31 PM |
| Oak Park table | old folks | Table-mounted Routing | 4 | 08-07-2007 11:08 AM |
| Design of Oak Park Router Table | susserj | Introductions | 6 | 07-06-2007 04:58 PM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 06:42 PM |
