Help
Go Back   Router Forums > General Woodworking > Project Plans and How To
Mounting an Oak Park Box Jig on Non Oak Park Table
This is a discussion on Mounting an Oak Park Box Jig on Non Oak Park Table within the Project Plans and How To forums, part of the General Woodworking category; Funny you should say that Bj. I was doing all of my tests using scraps ...
LinkBack (4) Thread Tools Display Modes
Old 10-01-2006, 07:07 PM   #31 (permalink)
mpphoto is on a distinguished road
Report Post Report This Post!
Funny you should say that Bj. I was doing all of my tests using scraps of 1/2" cherry and clamping two at a time. I played with the setup for a while using a 3/8" spiral bit. By the time I was done the bit seemed a little "tired". I should probably replace the bit anyway as I've had it for a while but I'm thinking with cherry I might run one board through at a time, especially with 1/2" stock.
Michael
mpphoto is offline
Old 10-02-2006, 09:01 PM   #32 (permalink)
Banned
Joe Lyddon's Avatar
Joe Lyddon will become famous soon enough
Corey & All,
I received my set of 3 jigs and I think they are of SUPER quality!
I setup the 3/8 jig just like you did... to get in place & test & all... finally, drilling holes.
My top was too thick for their screws... luckily, I had some longer ones on hand. I don't find much slack for the fine adjustment tool though... tight fit.
It took a little tinkering... mine were always on the tight side... still might be a little too tight.
I cut up some strips for testing... ended up making 2 boxes about 3 x 3.25 x 3.25 and one 1.5 x 3 x 6... As it turned out, all of the testing wood was good enough to be made into something useful!! I like it when that happens... Will show pictures later... didn't take any in-process pics... just the finished stuff.
Your writeup helped me a lot...
Thank you very much!
Joe Lyddon is offline
Old 10-02-2006, 10:11 PM   #33 (permalink)
challagan's Avatar
challagan is on a distinguished road
Joe I am glad it worked out. If you want to put a little adjustability in it you could drill one out of the holes in your top slightly so you have about 1/32 of adjustability. If you do that then you need to block and clamp it once you get the right fit and you would have to do test fits each time to get it just right.
challagan is offline
Old 10-03-2006, 10:18 AM   #34 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Guys
Just a hint/tip, don't drill the top out, and this is just my 2 cents, drill the jig out, if you have a cross vise for your drill press ,screw a block of wood to the back side of the jig about 1 1/2" wide clamp it into the vise and use a couter sink bit to make the hole a slot type counter sink slot, you can also do it will two boards clamped to the top side of the jig and on both side of the hole and do it free hand with care.
Do the counter sink 1st then drill out the hole.
This is for the 3/8" jig the others jigs (1/4" and the 1/2" ) just need to be drilled out to the next drill bit size (9/64") and they will work just fine.
Make the slot about 1/2" to 5/8" long , now when you want to use the jig for dovetails it's set up for it also plus now you can use the fine ajusting tool ( Bob's Hammer) to tap it into the right spot ,then lock it down.
Just a note***I use Allen Flat Head screws and tee nuts in my top and I also cut off the sharp points on the tee nuts and use glue to hold the tee nuts in place on the bottom side,a little dab of monkey glue and they are locked in forever.
The nasty sharp point on tee nuts just down like to go into most man made wood products,I cut them off to about 1/16" long with a pair of wire cutters to a new sharp point that way they hold but don't need to go into stock all the way.
Besure to use the right drill bit for the tee nuts (1/4-20 is a " N " if I recall that right) that way the barrel on the tee nut will pull in just right.
Bj
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 10-03-2006, 05:58 PM   #35 (permalink)
challagan's Avatar
Good idea BJ!
Old 10-05-2006, 04:15 PM   #36 (permalink)
Banned
Joe Lyddon's Avatar
Here is a link to the photo album where you can see the results of testing
the Oak Park router box joint jigs...
http://www.ncwoodworker.net/pp/showgallery.php?cat=842
Incidently, any of you can get setup and post images to the same site
as I have done...
It's FREE... No strings attached!
(and it's easy to use!)
Old 10-05-2006, 06:09 PM   #37 (permalink)
challagan's Avatar
They look good to me Joe!
corey
Old 01-03-2007, 10:56 PM   #38 (permalink)
JohnnyTest is on a distinguished road
Got a 3/8" for Christmas and was wondering when you make box joint boxes, how do most of you attach the bottoms. I was thinking a dado would be cool, but that could be tricky that you don't come out to the end and see it when assembled. I guess a stop block would work, but I am weary lowering it onto a bit to get it started.
JohnnyTest is offline
Old 01-04-2007, 05:02 AM   #39 (permalink)
bobj3's Avatar
Hi John
Putting the dado on all 4 parts can be a bit tricky but once you do it a time or two it's easy BUT you can attach the bottom part many ways.
One of them is to put in a rabbit cut on all 4 parts and just glue in the botom or top, one more way is to glue on the bottom and use a round over bit or a bead bit on the base so it looks like all in one box,one more way is to make the base over size and put on a rabbit cut so the sides slip down over the rabbit then put on a ogee bit and give it a nice cut.
Bj
Part Finder
Bob J.
Old 02-21-2007, 07:42 PM   #40 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
Corey..........you're photo-shoot is EXACTLY the sort of thing that I have been on about, just look at the interest that it created, imagine if every day a member or two posted similar photos. taken during a project,descriptions are one thing, but a series of photographs................definitely worth a thousand words. Congrats. on you're fine work. Harry
harrysin is offline
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/project-plans-how/3260-mounting-oak-park-box-jig-non-oak-park-table.html
Posted By For Type Date
9,553 Free Woodworking Plans, Free Wood working Projects & Scrollsaw Patterns This thread Refback 11-06-2009 10:07 PM
Woodworking Discussion Forum - Box Joint Jig This thread Refback 09-30-2009 05:37 PM
Workshop Router Tables and Router Accessories Free Woodworking Plans and Projects This thread Refback 09-11-2009 11:36 PM
Router Box Joint Jig - Woodworking Talk - Woodworkers Forum This thread Refback 03-20-2009 03:28 PM
Oak Park Router Table B_Rod Starting Off 27 02-20-2008 06:31 PM
Oak Park table old folks Table-mounted Routing 4 08-07-2007 11:08 AM
Design of Oak Park Router Table susserj Introductions 6 07-06-2007 04:58 PM
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 8 05-22-2007 06:42 PM
