| Project Plans and How To A place for member designed plans, suggestions about using purchased plans or to get help designing plans. Also, Step by step instructions and photos for building projects. |
| | #1 |
| Registered User Jr. Member | i am interested in making a router table. if you have any ideas on this subject i would like to hear from other members who have experienced this project. i am limited to how much i can spend as i am on a small pension thanks to all for reading my questions . good woodworking woodman1180 |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi woodman Because you are on a pension I would recommend the one from Rockler (see link below) it will come with all you need, all you need to do is install your router and fix it to a base that you can make once you have the top...or just pick up a cabinet at HomeDepot or one of the many 2nd hand cabinet shops. All you need to do is pop in your router in a WorkMate/saw horse setup and make your cabinet..if you need to, the cabinet can anything you have around. You will be $$$$ ahead by buying one that's done so to speak. http://www.rockler.com/product.cfm?p...router%20table Bj ![]() Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 05-30-2007 at 11:56 AM. | |
| | #3 |
| Marine Engineer Forum King | Woodman, my first homebuilt table was a sink cut out with an insert plate in it. My fence was a jointed 4x4. The thing worked OK, but I knew I wanted something nicer. The best part about starting with just a top was finding the height I liked to work at. No matter what route you go to build your table, (either buying a top, making a top) experiment with different heights to find what works best for you.
| | #4 |
| Registered User New Member | Good tip on finding the optimum height. I am currently figuring that out for myself, as we all are more comfortable with different heights for different tools. |
| | #5 |
| Registered User Supreme Forum King | A box with a top is the simplest to make. My first one was just that. I used 3/4" MDF for the top, and some old particle board shelves for the box. After using it for a while I made a new top for it and installed a router plate. http://www.routerforums.com/42525-post1.html The one I use now is a cabinet style that I made last year. It has room for most of my router tools, and was fun to build. http://www.routerforums.com/axlmyks-...e-cabinet.html Whatever you decide, look around to get some ideas. You may want to put T-tracks in the top and/or the fence for clamping things.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #6 |
| Registered User Forum King | Woodman, I ordered the Router Table plans from the New Yankee Workshop. I found the plan and the Video to be real easy. The material was not to expensive, it all depends on what type of material you use. Good luck. |
| | #7 |
| Registered User New Member | I am using 3/4" MDF (2' x 2'), with a pseudo torsion box underneath. I made a router plate from 1/4" lexan that my father-in-law had laying around, now I have to cut the hole in table and route out the area for the plate. I hope to have pics in a few days. |
| | #8 |
| Registered User Join Date: Mar 2008 Location: Wiesbaden Germany, when I'm not deployed to Afghanistan, Kuwait, or Qatar Posts: 1 ![]() | Howdy, I started out with an Eagle router tabletop mounted on a cabinet and moved it to folding saw horses for better dust control. It's now in storage somewhere across the ocean. So, I'm ordering the Oak Park table with the vac. plate while it is on SALE. The router workshop Router table is a proven system and much more than a collection of parts. Good luck <>< |
| | #9 | |
I think doug hit the nail on the head here. Doesn't matter what type of tool you have or setup. If you're uncomfortable working with it, you won't like it nor use it. I have the OP table with OP's stand. I ended up making a "I" frame under it with casters. This brought it up to a height that I'm comfortable working with.
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | |
| how should i build a router table | ntreaster | Table-mounted Routing | 2 | 06-28-2008 02:44 AM |
| Router Table Build Questions | deck99 | Table-mounted Routing | 20 | 11-01-2007 09:37 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 07:42 PM |
