| Project Plans and How To A place for member designed plans, suggestions about using purchased plans or to get help designing plans. Also, Step by step instructions and photos for building projects. |
| | #1 |
| Registered User Jr. Member | I'm thinking of making and selling cases for telescopic eyepieces. Astronomy is one of my hobbies (the quiet one) and have always had problems finding a case for my eyepieces that fit all my needs. Eyepieces are the main ongoing expense for amateur astronomers and we need safe, secure storage for them. I figured if I could start making these I could probably support my numerous hobbies. (I just want too many toys.) These will be similar to a regular briefcase in size but I need to make them sturdy enough to withstand nightly use in various temperature ranges. From what I've gathered so far a dovetail joint at the corners would probably be my best bet. I would like to make these out of red and white oak. I know I want to use a piano hinge at the back. If I use dovetails at the corners in a briefcase style box, would the case be sturdy enough to haul around with a single handle. I'll be using 5/8" oak stock for the sides. Also, what would be my best options for a finish? It needs to be enough to withstand relative dampness without damaging the contents. I assume I would want to varnish before putting on a water-proofer? Or is that backwards? What products would I want to check out for a finish? Sorry this is so long, I just don't want to put out something that's not going to last or serve its purpose. Thanks in advance for any advice. Last edited by tileart; 08-16-2007 at 11:42 PM. |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Roger You may want to take hard look at the MAGIC Box Bob N. just made, see link below http://www.routerforums.com/show-n-t...-finished.html http://www.routerforums.com/show-n-t...k-box-you.html With a flock job on the inside I think it would be just the ticket for your needs..plus no hinges needed...
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-17-2007 at 12:14 AM. |
| | #3 |
| Senior Moderator Supreme Forum King | White oak would be the most durable. As far as finish goes, a good marine spar varnish is as waterproof and durable as you will get. For added protection against the elements you could use a core box bit to cut a channel around the top and bottom edges and glue some O-ring material in place like a gasket.
| Display cases | Biglou13 | Project Plans and How To | 3 | 03-28-2008 07:15 AM |
