Go Back   Router Forums > General Woodworking > Project Plans and How To
Rate This Thread - material for radiator covers.
Thread Tools Display Modes
Old 10-04-2007, 11:22 AM   #1
peacefrog
Jr. Member
peacefrog is on a distinguished road
Default material for radiator covers
I've made several radiator covers for my house, but I have several more to go. I've been using mostly plywood rather than solid wood because the exposure to heat made me want something dimensionally stable. I've also been attaching a molding around the top to hide the plywood edge, then I paint the whole thing with latex.
Now it occurs to me that I could achieve a nicer look quite simply by using MDF and router a nice contour. That would also save me from cutting miters in the molding, which is always a challenge. Will the MDF withstand the heat? Do I need to do anything special to prime MDF, particularly around the edges?
Bob
peacefrog is offline   Top - Reply with Quote
Old 10-04-2007, 12:00 PM   #2
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Originally Posted by peacefrog
. . .Do I need to do anything special to prime MDF, particularly around the edges?
Don't know that this is a 'need to' thing or not -- probably not.
But it's something I did the first time I worked with MDF and I liked the way it turned out -- so -- I still do it.
I use a sandable primer --common in autobody work and model building - but available at the big boxes if you look hard.
It has some 'body' to it so it fills in the porous sides of the MDF -- then - a light sanding with some extra fine paper - and you should have edges as smooth as your top.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 10-04-2007, 12:06 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Bob
Think of MDF as a big sponge, when it gets wet or damp it will act just like a big sponge.
Stick with the plywood, it's very stable but it will also come unglued if it gets damp.
I think I would put a coat of shellac on both sides then put it in place..maybe 2 or 3 coats on the edges...
Bj
Old 02-20-2008, 08:13 PM   #4
fasttruck860
New Member
fasttruck860 is on a distinguished road
One other option would be to use MDO plywood. I think this would be your best option as it is exterior rated plywood and takes paint extremely well.
fasttruck860 is offline   Top - Reply with Quote
Old 02-21-2008, 12:52 PM   #5
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Hi Peacefrog Bob,
Just a reminder, since you are concerned with the wood warping. If you are covering a steam type radiator, the valve will expell a certain amount of moisture and cause inside problems. MDF should not be a problem if you first coat the ends with a mixture of wood glue and water and let it soak in. Then try the epoxy paints like they have in boating supply houses (expensive) or a sealer and good quality paint. Good luck.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Delta P-20 Material Holdown Clamping Screw rstermer Wood Scrolling 6 06-10-2008 06:27 PM
router table top material mharwell01 Table-mounted Routing 1 01-26-2008 04:14 PM
Plastic router fencing material mstevensjr General Routing 6 09-02-2005 03:28 PM
Table Top Material rh111 Table-mounted Routing 4 04-19-2005 03:35 AM
Material For Router Fence kvc Table-mounted Routing 7 10-11-2004 07:52 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
