| Project Plans and How To A place for member designed plans, suggestions about using purchased plans or to get help designing plans. Also, Step by step instructions and photos for building projects. |
| | #1 |
| Registered User Forum Geek | Was having a discussion at work with a friend who mentioned he had to build a table for his church. Not just any table, but a 12 foot long table that would be strong enough to support 4 complete computers, as well as various paperwork, coffee cups, and whatnot. It also had to have a rock hard finish on it to put up with years of abuse. He's not planning on making it fancy, but just nice and presentable. What might the best method be for fabricating a top? He's looking at birch plywood, but of course, it's only 8'. Any suggestiongs for joining 2 pieces? We discussed finger, box joint, and dovetail. He was als thinking of cutting the 2 end pieces on an angle and inserting a contrasting piece in the center. What about underframe construction? I suggested 2x4's laminated together at each corner with a dado cut about 6-8" for the bottom to insert a connecting 2x4 to stablize the legs. I've seen this done on many workbenches. Any better/other methods? For under the table support, I suggested 2x4 runners from end to end, doubled up via "glue and screw" construction. I was thinking this should provede sufficient support for the length and weight. For a hard surface finish, I suggested a polyurethane plastic coating. I don't think he's planning on staining, but not really sure. Are there better finishes than poly that will still provide the same protection from hard use? Looking for any suggestions that you might have. Thanks in advance Brian
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Brian Because it's for his church I would suggest the type of table below, they do come in 12 ft. long ...and once he's done with it can be used in many other ways.. plus they are light and can be folded up and put away ...and I'm sure it would cost less than making one ![]() I have many of the 8ft. ones and they do come in handy for computers...just the right size and height... http://www.officedepot.com/textSearc...=folding_table =================
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-26-2007 at 10:22 AM. |
| | #3 |
| Registered User Forum Geek | Thanks Bj. I always seem to forget about these... and I even have one!! Think I'll suggest 2 6 footers to him, much easier to store if needed. Brian
| | #4 |
| Registered User Supreme Forum King | If you intend on joining pieces that large, you may consider using the T&G bit. But, Bob's suggestion would be the best way to go. ![]()
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #5 |
| Senior Moderator Supreme Forum King | If your friend wants to build a 12' table as opposed to buying one here is a simple solution for the length: two 6' foot long plywood panels. Working left to right cut a 1" wide rabbet, at the 3' mark cut a 1" wide dado, the right side of the panel cut a 1/2" wide rabbet. Mirror image the other panel. Cut five 1" wide strips of hardwood, 3/8" thick.The outside ends and dado's are to divide the table into quarters for appearance. The center piece will join the two panels together. Glue and screw from the bottom. Add a 12" wide section of plywood centered under the joint to give added support. Glue and screw it in place. Wrap the outside edge of the entire table with the same hardwood strips. As long as the hardwood strips are a different wood than the ply it will look nice when you add a coat of any color stain, then top coat with 3 applications of poly.
| Looking for input on home built router table | italian biker | Table-mounted Routing | 1 | 05-29-2008 08:07 AM |
| Router Table Help Which One! | bigroccrek | Table-mounted Routing | 25 | 04-08-2008 11:57 PM |
| First and only (I hope!) Router table | CanuckBeaver | Table-mounted Routing | 11 | 07-25-2007 03:45 PM |
| Cubbie's Router Table | Cubbie | Table-mounted Routing | 4 | 03-19-2005 04:13 PM |
