Go Back   Router Forums > General Woodworking > Project Plans and How To
Project Plans and How To A place for member designed plans, suggestions about using purchased plans or to get help designing plans. Also, Step by step instructions and photos for building projects.
Thread Tools Display Modes
Old 03-30-2008, 11:29 AM   #21
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
Thanks Bj. I can still do the deed to the table. Still thinking on it.
Nice bit set.
AxlMyk is offline   Top - Reply with Quote
Old 03-30-2008, 12:20 PM   #22
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome Mike
And thanks,, but do try one of your R & S bit sets I think you will be amazed and easy it is to do.. and how well it comes out and you had the bit set all long works great on a plywood edge becasue as you know plywood is undersize....stock..but do use feather boards to hold it down and to the fence also use wider stock and then rip it to size after, in that way you can do 2 parts at one time so to speak...(banding) plywood is no big deal but do use a board (clamp to the fence) or feather board to hold the plywood down to the table top, note it must be done in one pass.
Just a note***most R & S bits have a bearing on them use it to set the fence, some come with only one bearing on one bit, use that one 1st, use a stop block on the back side of the fence to get it back to the same point after you switch the bits out, you can also use some masking tape or a pencil to mark the table top so you can get the fence right back to the same place after the bit change...
Once you do it a time or two you will always put banding on your projects becasue it's so easy to do and it puts that nice touch to the project..
Open/End grain is always nasty looking and it's one of the hard things to finish on any project..but once it's banded it's clean..
One of the neat things about using R & S bit's no fasterns are needed it's self locking so to speak ,if you pull one shim out of the bit ,,,,,(the female bit)
Just one more note***** if you send off for one of the bit sets (door sets) besure to check the nuts on the bits b/4 you use them, I didn't I forgot to and one did spin just a bit ,it's going to remove alot of stock in one pass and it needs to be real tight... I got a bit noise and I said what the hell and it was the nut that had come free...
Nice bit set.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 11:57 PM
First and only (I hope!) Router table CanuckBeaver Table-mounted Routing 11 07-25-2007 03:45 PM
What Router Bit for Table Edging? Clem Wixted General Routing 40 06-14-2007 02:47 PM
Cubbie's Router Table Cubbie Table-mounted Routing 4 03-19-2005 04:13 PM
