| | #1 |
| Registered User Sr. Member | I’m planning a single-drum compost tumbler that is similar to the one shown here http://www.instructables.com/id/Doub...rum-Composter/ What I would prefer to do is make an A-frame from 4×4s and a 2×6 crosspiece. The drum would be mounted on a pipe that would go through the 2×6 braces. I would prefer not to use big lag bolts and such on this project… I would prefer not to use any metal at all if I can get away with it, actually. I figured that I would miter the 4×4s so that they would join up at the top but I can’t think of a good joinery method for up there beyond a big old lag bolt. If I just bolt the 2×6 onto the 4×4s then it should be strong enough to support the weight but I don’t think that it would be very attractive. How would YOU do it? Jon
__________________ Modern Daguerreotypes: original pieces or custom made from your images. shinyphotos.com |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Jon Do you recall how they made barns about 150 years ago, with one or two dowel pin(s) holding all the timber locked in place...they are neat looking and strong... Without the need of any metal fastners.. You may ask how to do it...this is what I would do ![]() Do the 2 x 6 on the router table that way you will get a nice clean cut on the 2 x 6 then get the saws all out to cut the 4 x 4 or to say put the slot in the 4 x 4 post..then once it fits just right clamp it up and dril the 2 holes out with 1" spade bits then drive one pin in then the other unclamp it and your done.. But YOU still need to dig the holes for the 4 x 4 post and just pack some gravel around the 4 x 4 so the water can run away from them other than soak in to the 4 x 4's ![]() Have fun.. ========= ============
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 04-13-2008 at 12:34 AM. |
| | #3 |
| Registered User Dedicated Member | i just saw a show on the old style of joinery & they put the dowels in on an angle & that helps to draw the 2 pieces tight as the dowel is hammered into place. les. |
| picture frame techniques | reds_21 | Tools and Woodworking | 5 | 04-13-2008 09:54 AM |
