Up spiral or down spiral solid carbide? - Router Forums
post #1 of 11 (permalink) Old 12-22-2008, 07:59 AM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default Up spiral or down spiral solid carbide?
Hi
I'm going to need some of these for the Woodrat I've got coming. I suddenly realized that my UK supplier has sets of these (1/4", 3/8" and 1/2") at only 2/3rds of the price they charge for them individually. I suspect they won't be that for long and as the Pound falls further new stock will be more expensive, so I'd like to get some now.
I've no experience of them. Which are more likely to be useful, the up spiral or the down spiral ones,please?
Cheers
Peter
istracpsboss is offline
post #2 of 11 (permalink) Old 12-22-2008, 09:40 AM
Hi Peter
I would suggest both, anytime you can get a great deal on router bits grab them...
You can't have too many router bits..
Originally Posted by istracpsboss View Post
Hi
Cheers
Peter
post #3 of 11 (permalink) Old 12-22-2008, 10:33 AM
Ralph Barker's Avatar
First Name: Ralph
It seems to me that "up" and "down" are relative. Sometimes up is actually down.
That is to say, it depends on how the router is being used. For edge routing over an empty space, a down spiral might be most convenient, while in a router table, an up spiral, now turned upside down, might be the best.
- Ralph
Ralph Barker is offline
post #4 of 11 (permalink) Old 12-22-2008, 10:59 AM
Hamlin's Avatar
First Name: Ken
Hi,
Bj is correct, you should get both while the price is right. Never turn down a good deal.
As I've said many times before, they each have their uses.
Ken
"A VETERAN"
Hamlin is offline
post #5 of 11 (permalink) Old 12-29-2008, 12:19 PM Thread Starter
Country: Croatia
First Name: Peter
Many thanks for the responses. I must admit that it hadn't occured to me that of course using them in a router table will work the opposite way round, so I'd need both.
Thanks!
post #6 of 11 (permalink) Old 12-29-2008, 01:14 PM
dovetail_65's Avatar
First Name: Dovetail
I believe the bits made for and recommended by Woodrat are HSS and not carbide. Look at this deal carefully checking for that before purchasing.
dovetail_65 is offline
post #7 of 11 (permalink) Old 01-06-2009, 08:52 AM Thread Starter
Country: Croatia
First Name: Peter
Yes, they are, but I think that is primarily for the dovetail bits, where you can get a more delicate shape and finish out of HSS. I get the impression that solid carbide straight spiral bits are considered useful as well for other work.
Incidentally, I've found an even cheaper source of sets in the States (MCLS)
Cheers
Peter
post #8 of 11 (permalink) Old 01-06-2009, 09:07 AM
First Name: Bob
Yeah, I'm loving the MLCS pricing on the spiral sets... have one (upcut) on the way, holding out on downcuts until I need them, but the upcut I wanted to have on hand.
thistlefly is offline
post #9 of 11 (permalink) Old 01-06-2009, 10:23 AM
Ok, time out. There is a problem understanding how these bits work. Up and down does not make any difference between table mounted or free hand use. This is how they work:
An up cut spiral pulls debris out of the cut towards the router and is best for solid wood.
A down cut spiral pushes debris away from the router and into the cut. This type of bit is used for cutting part way through plywood and surfaces with veneer or laminate attached. This prevents pulling the laminations apart.
A compression or combination spiral bit is used for making cuts through plywood or material with veneer or laminates. The cutting action squeezes the material together to prevent tear out.
All of these bits should be solid carbide. HSS bits work great on steel but overheat and dull in minutes when working with wood. You can save a lot of trouble trying HSS bits by placing your money in the toilet and flushing it.
Most people will find the up cut spiral bits get used more than other bits, so start with a set of these.
post #10 of 11 (permalink) Old 01-07-2009, 04:06 AM
Since solid carbide spiral bits are so expensive, I compromised. I bought 1/4", 3/8", 1/2" solid carbide spiral upcut bits. But I bought carbide tipped down shear bits in the same 3 bit diameters which were cheaper. If I need a clean cut with no fuzzies on the edge, I'll use the down shear bits.
Skyglider is offline
Human Verification
Carbide or HSS crquack Router Bits - Types and Usage 16 01-04-2009 04:39 AM
Spiral up or spiral down slumlord Introductions 6 12-14-2007 12:54 AM
Spiral Bits RustyW Router Bits - Types and Usage 5 08-18-2007 10:47 AM
Solid Carbide Bits - More likely to loosen? Chris H Router Bits - Types and Usage 2 01-12-2007 04:46 PM
Spiral bits? archer_456 General Routing 6 04-11-2005 10:31 PM
