Router Bit Bearing Question - Router Forums
 8Likes
post #1 of 13 (permalink) Old 03-19-2017, 10:10 AM Thread Starter
Default Router Bit Bearing Question
Can I use a hardware store bearing on a router bit or is there something special/unique about router bearings?
JIMMIEM is offline
post #2 of 13 (permalink) Old 03-19-2017, 10:39 AM
as long as it's sealed and rated for the speed....
yur good to go...
MEBCWD likes this.
post #3 of 13 (permalink) Old 03-19-2017, 10:55 AM
A bearing is a bearing. I've hear that there are only a few companies in the world that make them now. Same for TVs and major electronics. I've never seen any at the hardware store that small.
post #4 of 13 (permalink) Old 03-19-2017, 11:44 AM Thread Starter
yur good to go...
Thank You!!!
JIMMIEM is offline
post #5 of 13 (permalink) Old 03-19-2017, 11:47 AM Thread Starter
Actually I was looking for a larger one.... 1 1/2" diameter.
JIMMIEM is offline
post #6 of 13 (permalink) Old 03-19-2017, 12:38 PM
Use a rub collar on the existing one. This is the general idea. I have a set of four that came from Woodstock or Woodriver or wood something I think. https://www.woodstockint.com/product...rs/rub-collars Some of the rabbeting sets I've seen use them for the larger sizes.
chessnut2 likes this.
post #7 of 13 (permalink) Old 03-19-2017, 12:50 PM
Normally router bits have some various sized holes that are not common to shaft bearings. I have noted too that different brands have different hole sizes for same profile bits. Most bit companies sell the bearings separate for their bits. it is the off shore bits that are a problem replacing bearings with the same size holes. Also have to contend with metric and imperial hole sizes.
paduke likes this.
Herb Stoops is online now
post #8 of 13 (permalink) Old 03-19-2017, 12:56 PM
find a bearing wholesaler...
post #9 of 13 (permalink) Old 03-19-2017, 04:16 PM
JOAT's Avatar
First Name: Theo
Huh, now that's interesting. No use for one, but still interesting. I guess you guys run across stuff like this, that I've never even heard of, because of your routing needs. Me, I just use the same style bits, year after year, 1/4" shank, 1/2" bit, 1" bit length, bearing on top. I never look for anything else, so I don't find anything else. But, they do just what I want, so I'm content. But still like to see what some of you come up with, educational you might say.
NC via the Army in 1979; retired 1981, just east of Raleigh ever since.
Remember, when I tell how I do something, that does not mean I recommend you do it my way. Different backgrounds, experiences; what works for me, may not for you.
No point in believing in things that exist. If they exist, you don't have to believe, they just are.
JOAT is offline
post #10 of 13 (permalink) Old 03-20-2017, 08:43 AM
First Name: Bob
Wow first time I will disagree with Stick! Brg is mot a brg. After 42 years in the power transmission bearing business I think anything that has speed or load needs precision. Chinese manuf. is the lowest grade right now but getting better. SKF, FAG, are from Europ. NTN, NSK are from Japan. Fafnir which are now Timken are USA. Most brgs are metric but inch diameter though less common are available. Suppliers such as AIT ( Applied Industrial Tecknologies), Kaman and Motion Industries are the big boys in the States and will be able to help you. Possibly even on line. There are some brgs with inch inside diameter and metric outside diameter and width. Make sure yo measure. Bearings are available with seals and shields amd are prelubed. Do. ot try to lubricate your self as the most common problem with brgs is over lub rearing to much heat. Sounds crazy but true.
Sorry for the long answer.
Goodsoil is offline
Human Verification
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Harsh question about a router bit Greeneyedeagle Router Bits - Types and Usage 13 03-25-2009 05:19 PM
New here burlboy Introductions 9 01-15-2009 11:53 AM
