| This is a discussion on Whats the difference between router and shaper bit? within the Router Bits - Types and Usage forums, part of the Routers category; Whats the difference between router and shaper bit? I know a 1/4" router bit is ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Whats the difference between router and shaper bit? I know a 1/4" router bit is not the same as a shaper bit...duh. But is a 1/2" router bit the same as a 1/2" shaper bit? In other words, is the shaft size the determining factor? Or is there factors about 1/2" shaper bits that are differant from 1/2" router bits? Can I buy the same bits for a 1/2" router as for a 1/2" shaper? | ||
| | #2 (permalink) | ||
Shaper bits don't have shanks, they have holes so they can be put on a spindle. A half inch shaper bit will fit on a half inch spindle. Shaper bits are also much heavier and larger in diameter. The carbide is usually thicker as shaper bits are designed for production work. You can get a lot of shaper profiles on a router bit, but they won't be as large. You also need a 3 HP router with variable speed to run them. | ||
| | #3 (permalink) | |||
| Forum Contributor ![]() |
Hi sofasurfer It's not so much as the bit/cutter ,you can use the standard router bit on the shaper but you can't use the shaper cutter on the router table.. With a adapter that you put on the shaper it will take on almost any router bit. They make many more profiles for router bits than cutters for the shaper. You can get VS motor control to slow the shaper down for the big panel bits.. ============ Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #4 (permalink) | ||
| Official Greeter ![]() |
Greetings (your name here) and welcome to the router forum, good to have you join us.
__________________ Wisdom: Where experience and knowledge combine and become one. "We are all one decision away from Stupid!!" Lamentations 3:22-23 "How often we sacrifice the permanent plans of God on the altar of immediate solutions" I have a very good memory, just short is all. | ||
| | #5 (permalink) | ||
| Forum Contributor ![]() Join Date: Sep 2004 Location: New Lebanon, Ohio "USA" First Name: Dave or "Doc" Posts: 8,762 ![]() |
Welcome to the RouterForums "sofasurfer."
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. ![]() Please Please Please edit your profile with a name and location so we can better assist you and make for a friendlier forum.![]() Thank you. | ||
| | #6 (permalink) | ||
| Registered User ![]() Join Date: May 2007 Location: I was born and raised in Holland Michigan First Name: Howard Posts: 1,519 ![]() |
The other advantage is that the shaper can run in forward and backward. Sometimes it is hard to run an edge on a piece with a router. with a shaper, you can reverse the bit, and run backward, so instead of having to run the finish side on the shaper, you can shape it with the good side safe. No sliding the finish on the bed.
__________________ John 3:16 Please fill out your profile, It helps us to know you better | ||
| Hello | DPugmire | Introductions | 4 | 01-08-2009 04:26 PM |
| Intro and question | john spies | Introductions | 16 | 01-06-2009 10:05 AM |
| When does a router table become a shaper | Bogydave | Table-mounted Routing | 22 | 12-21-2008 12:38 PM |
| Router vs. Shaper | rstermer | General Routing | 8 | 05-11-2008 04:10 AM |
| router table or shaper? | flyboy8224 | Starting Off | 6 | 12-03-2007 01:39 AM |
