Help
Go Back   Router Forums > Routers > Router Bits - Types and Usage
Bearing Bit Problem
This is a discussion on Bearing Bit Problem within the Router Bits - Types and Usage forums, part of the Routers category; Tonight, I went out to the shop to round over the edges of the two ...
Old 06-10-2009, 11:23 PM   #1 (permalink)
rstermer is on a distinguished road
Default Bearing Bit Problem
Report Post Report This Post!
Tonight, I went out to the shop to round over the edges of the two braces I made for a folding workbench I'm building. I'm new to routing and had purchased a 68 bit set at a show so I'd have a good assortment of bits to learn on. Most of the bits are still unused. I installed one of the roundover bits for the first time and tried it out on a test piece. At first it worked very well, but after resetting the cut depth, it started cutting far too deeply. I tried resetting the cut depth , but no combination was working. Finally, I took a close look at it and realized that the screw holding the bearing on had come loose and the bearing had slipped off. Changing to a slightly larger bit solved the immediate problem, but I'm wondering if maybe a drop of Locktite on those retaining screws or a small serrated washer under the screw head would be a good idea? What do you do?
I feel lucky the flying screw didn't tag me and don't want any recurrance of this problem.
rstermer
rstermer is offline
Old 06-11-2009, 04:47 AM   #2 (permalink)
Drew Eckhardt is on a distinguished road
Originally Posted by rstermer View Post
T What do you do?
Make sure the screw is torqued correctly and it's not going to go anywhere. As long as the parts aren't moving relative to each other that's enough to hold things together even when you lubricate bolt/screw threads with oil or anti-seize.
Check the tightness once you've installed the bit and still have the spindle lock engaged or a wrench on it.
Drew Eckhardt is offline
Old 06-11-2009, 07:29 AM   #3 (permalink)
dutchman 46's Avatar
First Name: Howard
dutchman 46 is on a distinguished road
I have a bearing just like that. I WOULD TRY A TOUCH OF Lock tite. Nothing short of that has been able to hold mine. And i believe it is a Bosch.
John 3:16
dutchman 46 is offline
Old 06-11-2009, 09:03 AM   #4 (permalink)
Mike will become famous soon enough
The answer to the problem is all new bits need to have the bearing screws checked, most are shipped loose. While Loctite and even a drop of nail polish will work to secure the screws the best solution is to use a product called Vibra-tite. Apply to the threads and let sit over night. Here is the great part: You do not need a solvent to remove the screw. You can replace and adjust the screw and after 24 hours it will re lock. This is the only product that has this feature. Vibra-tite is sold world wide by ND industries. As a side note of interest the ND stands for Nylok-Detroit.
Old 06-11-2009, 09:12 AM   #5 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
I have to say that in all the many years that I've been routing, I've never had that happen, try tightening the screws on all your cutters as has been suggested, whilst Locktite would certainly fix the problem for ever, there are times when for various reasons the bearing needs to be changed.
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 06-11-2009, 01:11 PM   #6 (permalink)
Thanks, Harry- Locktite comes in various strengths. The red locktite is permanent and, once applied, the screw probably can't be removed. Blue locktite (medium strength), supposedly allows one to remove the screw, although I have my doubts insofar as very small diameter screws are concerned. We shall see. I was happy to hear that this problem has never happened to you, makes me feel like less of a dummie as to my woodworking. It seems I create a lot of scrap, no matter how careful I am, but then I do have a lot of fun doing it, and as time goes by can see a good amount of improvement, so am hopeful at some point I will achieve a minimum level of competance.
Drew & Mike- Thanks for your input. I will certainly check all the screws to make sure they are tight and will look into Vibra-tite.
Dutchman- Thanks. What color locktite did you use?
Thanks to all,
RAS
rstermer is offline
Old 06-11-2009, 01:30 PM   #7 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi rstermer
Locktite is great stuff but you don't need and go out buy some,just open the drawer on the tool box.most have some BLUE STUFF gasket stuff in the tool box,put a dot in the hole and it will hold the screws in place..
The error comes from the tap hole,most are taped out in a 2A fit and the set screws are made in a 3A fit ( pitch) the blue stuff will fill the gap in the threads and let it hold like it should..plus you can remove it or adjust it at anytime..
That's what Locktite does but makes it hard as a rock in time..
Thanks to all,
RAS
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 06-12-2009, 10:08 AM   #8 (permalink)
First Name: Howard
I had some of the blue. I haven't used the bit in a while, It might be time to rethink my fix
John 3:16
loose bearing housing mewanchyna General Routing 9 02-13-2009 12:06 AM
Flush Trim Bit Top Bearing vs. Bottom Bearing steveD Router Bits - Types and Usage 14 12-22-2008 01:36 PM
Top bearing sliding up shaft MisterHeavy Router Bits - Types and Usage 3 04-28-2008 02:02 AM
Removing bearing? Drugstore Cowboy Router Bits - Types and Usage 3 06-23-2007 03:05 PM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 2 10-22-2005 06:41 AM
