Help
Go Back   Router Forums > Routers > Router Bits - Types and Usage
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the largest router and woodworking community on the web! Join in over 20,000 discussions with over 40,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Minimum bit depth
This is a discussion on Minimum bit depth within the Router Bits - Types and Usage forums, part of the Routers category; Just wonderring if there is a minimum depth the bit comes out below the fixed ...
Old 06-25-2009, 08:47 AM   #1 (permalink)
bill0199 is on a distinguished road
Default Minimum bit depth
Report Post Report This Post!
Just wonderring if there is a minimum depth the bit comes out below the fixed base. What I mean is, if i am buying a 1/2 diameter straight bit, why would I buy something with a depth of 1/2" when I could by one that is 1 1/2 for example. I am assuming using your plunge base you could then go from any depth between 0 to 1 1/2" (not planning to route anything 1 1/2 at a time but you get the picture). Just wonderring, on a fixed base if you chucked a 1 1/2 deep straight bit on it if there was a minimum distance the bit would be below the surface. If not why limit yourself by buying a 1/2" depth bit?
bill0199 is offline
Old 06-25-2009, 09:10 AM   #2 (permalink)
harrysin's Avatar
First Name: Harry
harrysin is a name known to allharrysin is a name known to all
The shorter the cutter the more rigid it is therefore it can be fed that much harder without fear of breaking. I tend to only use long cutters where they are necessary for the job in hand.
Harry
Information's pretty thin stuff unless mixed with experience. - Clarence Day
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 06-25-2009, 10:13 AM   #3 (permalink)
Mike will become famous soon enough
Bill, there is a need for both long and short cutters. Since most people want the maximum value they can get from a bit I suggest buying something in the 1-1/2 to 2" range to start with. This will let you do more jobs. As your bit collection increases adding a short bit could improve accuracy. I am not a fan of bit extenders, I would rather see a longer bit.
Sponsored Advertisements. Register to disable this advertisement.
Old 06-25-2009, 11:19 AM   #4 (permalink)
Thanks guys, and yes Mike economy to begin with is the key here. Just thought to start i would go with around 1 1/2 . And really, to start I would feel more comfortable going with a couple of shallow passes to get to my desired depth anyway. Thanks again. But still, one part of my question to you guys is; on a fixed base router will a 2" long bit go right up inside the housing and leave no bit exposed below the base or is there a max. depth inside the router?
bill0199 is offline
Old 06-25-2009, 11:19 AM   #5 (permalink)
Mike Wingate's Avatar
First Name: mike
Mike Wingate is on a distinguished road
I agree, it's best to have a variety of lengths.
Mike Wingate is offline
10% OFF at Rockler.com!
Old 06-25-2009, 11:28 AM   #6 (permalink)
curiousgeorge's Avatar
First Name: George
curiousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to beholdcuriousgeorge is a splendid one to behold
I don't think most fixed base routers will accept a 2" bit without having some of the bit extending past the base plate. The only way to be certain is to measure at minimum depth setting from inside the collet to the bottom of the base plate.
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is offline
Old 06-25-2009, 01:27 PM   #7 (permalink)
ahhh. so the combo i purchased with both fixed and plunge base was a wise one. Thanks. Very excited to start making some sawdust. First up... building my workbench.
bill0199 is offline
Shop now at Tool King!
Old 06-26-2009, 08:07 AM   #8 (permalink)
harrysin's Avatar
First Name: Harry
Yet another reason George to support my opinion that fixed base routers should be delegated to the museum. Plunge routers as YOU know George are far superior.
Harry
harrysin is offline
Old 06-26-2009, 08:10 AM   #9 (permalink)
harrysin's Avatar
First Name: Harry
"I am not a fan of bit extenders"
By golly Mike, we are in complete agreement!
Harry
harrysin is offline
Shop now at Rockler.com!
Old 06-26-2009, 09:00 AM   #10 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Harry
I must disagree with you and Mike,,extenders do have a place in the shop, so many router bits are just to short ,,( dish cutter for just one of many) many will pull the bit up and to far out from the collet to get around that error ,the Collet Extension will do the job SAFE I use the router table dovetail jig alot and the bits are longer than the norm but they are just to short most of the time...many of the strait bits come longer but most of the other router bits just come in one size, then if you add a template or a sled the bit must be longer in order to do the job.. and safe..
Router Collet Extension
Router Collet Extension and review
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
How to Remove and Reinstall a Drill Press Chuck
See all 48 videos, Great tips.
http://www.youtube.com/watch?v=KbI_7...=31&playnext=3
HOW TO Inset a Router Base Plate
http://www.popularwoodworking.com/ar...e_plate_video/
Wood Working Videos, many great ones.
http://web.me.com/deceiver6/Deceiver/wwvideos.html
Router Tables
Router Tables Made Easy, with this video.
http://www.sommerfeldtools.com/Route...ductinfo/DVD3/
http://www.youtube.com/watch?v=sFW5gBYwt4M
http://www.youtube.com/watch?v=QjW5H...eature=channel
bobj3 is online now
shank depth pemdas86 Router Bits - Types and Usage 5 02-12-2009 01:55 PM
Dealing with depth when changing bits uOpt Starting Off 6 01-05-2009 01:14 PM
Depth adjusting ring doesn't turn. waynecathy33 Introductions 4 11-17-2008 11:35 PM
Sloppy depth settings!! Birch General Routing 4 04-06-2007 07:13 AM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 01:20 PM
