How to setup a Finger Joint Assembly Router Bit - Router Forums
post #1 of 15 (permalink) Old 12-15-2009, 02:13 PM Thread Starter
Country: Sweden
First Name: Anders
Default How to setup a Finger Joint Assembly Router Bit
Hi all experts.
I'm struggling with a simple setup routine for my Finger Joint Assembly Router Bit (copied this from the web, don't know the correct name in English).
I've made a list with setup values(router bit height from table) depending on the thickness of my boards. But it seems like I'm doing it wrong. Despite my (in my opinion) good calculations I'm getting some difference between the two boards when mounting. I've read that setup should be at centerline on both bit and workpiece, but that's VERY difficult to measure.
I'm using it for both end to end and edge to edge. It's very tedious to setup with the trial & error method.
// Anders
Bychen is offline
post #2 of 15 (permalink) Old 12-17-2009, 11:39 AM
Hi Anders;
What are you building? Are you trying to put end to end & edge to edge together at same time? Try using a glue joint bit for edge to edge or even biscuts.
Here's another set of instructions for the finger joint.
http://www.mlcswoodworking.com/shops...ingjnt0911.pdf
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 15 (permalink) Old 12-17-2009, 11:59 AM
Hi Anders
Sounds like you are takling about a box joint, some times called a Finger Joint, a jig is needed to get them right every time...
Many sale the jigs but the best one I have found is the OakPark one...it can be used in many ways not only for the box joint.
see below
Spacer Fence - Oak-Park.com
Oak Park Enterprises Ltd.: Catalogue
You don't need all of them but you will glad you have all 3 of them.
Originally Posted by Bychen View Post
Hi all experts.
// Anders
post #4 of 15 (permalink) Old 12-17-2009, 12:43 PM Thread Starter
Country: Sweden
First Name: Anders
Originally Posted by jlord View Post
Hi Anders;
Thank you for your quick response.
My question was more of a general kind, I sometimes use finger joint bit instead of biscuit's when I glue edge to edge (like doors or sides). I think it looks nice. I'm also using finger joint bit end to end (strength).
My real question is..
I wonder if anyone have found out a simple method for set up.
The "shoulders" must be equal height and this means that the bits centerline and workpiece centerline must match, this is difficult to set up. I would rather have a height measure from router table to one of the teethes on the bit depending on workpiece thickness.
The attatched PDF describes the set up, but it doesn't contain any tips for doing it the easy way.
Maybe there is no easy way.
//Anders
Bychen is offline
post #5 of 15 (permalink) Old 12-17-2009, 12:46 PM
gav
Country: Croatia
First Name: Gavin
I don't think he is talking about box joints.
I think he is actually talking about finger joints as per this link....
Finger Joint Assembly Router Bit - Toolstoday.com - Industrial Quality Carbide Tipped Router Bits
I can't help with the set up though, except that it seems you should only be using the router table and not a hand held router.
Looking at the picture I can only assume that you should align the top of the cutter with the top of the wood. Looks like you would also have to ensure that the wood is the same thickness as the cutter.
Not sure as I've never done it.
gav is offline
post #6 of 15 (permalink) Old 12-17-2009, 12:49 PM
gav
Country: Croatia
First Name: Gavin
I guess i was too slow typing.
So it is in fact a finger joint cutter.
Looking at the pdf you posted, it doesn't seem like there is an easy way.
Do you have 'micro adjust' on your router ? That would make it easier.
gav is offline
post #7 of 15 (permalink) Old 12-17-2009, 12:50 PM
Use the same video to set up the finger joint bit
for butt loints
MLCS Finger Joint, Box Joint, Window Sill Carbide Tipped Router Bits
http://cgi.ebay.com/1-PC-1-2-Shank-A...item1e599492f9
http://cgi.ebay.com/2pc-1-2-SH-Adjus...item1e59a3965a
post #8 of 15 (permalink) Old 12-17-2009, 12:56 PM Thread Starter
Country: Sweden
First Name: Anders
Hi Anders
Hi,
Box joint wasn't what I meant, but this jig looks really nice, I have to check availability in Sweden. I have seen some videos showing some real nice pieces made with these jigs and easy methods, requiring very little set up.
Their router tables looks wonderful, I haven't found any reseller in Sweden.
//Anders
Bychen is offline
post #9 of 15 (permalink) Old 12-17-2009, 01:08 PM Thread Starter
Country: Sweden
First Name: Anders
Great video, a sled is a good idea, I'll make one this weekend.
Bychen is offline
post #10 of 15 (permalink) Old 12-17-2009, 01:21 PM Thread Starter
Country: Sweden
First Name: Anders
HI, Maybe I was to slow reading
Yes, I have the possibility to adjust my router. The easy way may be 6 fixed workpiece dimensions (13, 19, 22, 25, 32 and 45 mm) and make set up templates for each thickness.
//Anders
Bychen is offline
Human Verification
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Adjustable Finger (not Box) joint bits jschaben Router Bits - Types and Usage 8 07-26-2009 11:18 PM
Rockler Router Table Box Joint Jig jimcrockett Table-mounted Routing 6 12-17-2008 09:58 PM
Router forums tall tails reible Lobby 11 03-03-2008 12:22 PM
Help Router Table assembly darrell0555 Starting Off 2 11-25-2007 01:39 AM
Chipout when using finger joint jig jihhwood Jigs and Fixtures 3 01-03-2007 08:33 AM
