| This is a discussion on Router Bit within the Router Bits - Types and Usage forums, part of the Routers category; I purchased Freud 99-036 Adjustable Tongue and Groove Bit Set 1/2 inch I tried to ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I purchased Freud 99-036 Adjustable Tongue and Groove Bit Set 1/2 inch I tried to make an adjustment and found no place on the shaft to put a wrench. How does one hold the shaft to loosen the nut without damaging the shaft. | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
Chuck it up in your router. The nut on the bit should loosen before the nut for the collet.
__________________ James Whittier, CA. Just because you can, doesn't always mean you should Have a nice & safe day! | ||
| | #4 (permalink) | |||
__________________ James Whittier, CA. Just because you can, doesn't always mean you should Have a nice & safe day! | |||
| | #5 (permalink) | ||
| Forum Contributor ![]() |
Hi phillipd You will need to made a quick jig, take block of hardwood, about 2 x 2 x 6" long drill a 1/2" in the center of the block, then take it to the band saw and split the board right down center , right through the the 1/2" hole .but down go all the way on the split, stop short about 1/2" or so from the end, rap some tape around the end without the split on it.. now put the bit in the block and clamp it in your vise, now switch the bits or remove the shims,Don't do it on the router table it's so easy to drop parts down the hole.. ![]() Note you may want to drill a 1/4" at the same time for the 1/4" shank bits. ========
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos Last edited by bobj3; 01-19-2010 at 11:14 AM. | ||
| | #6 (permalink) | ||
What happened to the kiss rule? What if there is no band saw available? The collet in the router should hold the shank tight enough to loosen the nut on the bit. No jig to make. That's faster than making a quick jig.
| | #7 (permalink) | |||
__________________ Rusty If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It | |||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | ||
Hi James Very true, the little thin spacers are slick when you pull them of the shank and they can drop so quick down the deep dark hole, most don't count them, they just pull them off and sit them down on the table top, if they drop down inside the hole you are in for some real work,did that done that, like they say if it's worth doing it's worth doing it right, not to say anything about taking the chance of nicking the cutter with the wrench ,it's true some router bits have a wrench flats on the router bit shank but it's best to pull them out of the router table, I know you have seen Marc of sommerfeld tools do it all the time but he has been using the router table a very long time, and I'm sure if he did they would cut that part out of the video.. ![]() By the way most have a hand saw hanging on the wall that works just like a band saw the KISS way for sure ..=========
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos Last edited by bobj3; 01-19-2010 at 10:00 AM. | ||
| | #9 (permalink) | ||
Thanks to all who posted a reply. I will try Bobj3 suggestionand make the jig Thanks again Phillip | ||
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 17 | 10-11-2012 05:20 PM |
| Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table | bigdave720 | Table-mounted Routing | 12 | 04-05-2012 07:27 PM |
| Router Recall (PC, SEARS, RYOBI) | Birdflu | General Routing | 5 | 02-23-2012 10:01 PM |
| How do I mount a Router to a table | demaX | Table-mounted Routing | 3 | 04-16-2009 06:56 AM |
