| This is a discussion on Router bit within the Router Bits - Types and Usage forums, part of the Routers category; Hi to all, I'm searching for a molding bit that looks like this. The only ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Hi to all, I'm searching for a molding bit that looks like this. The only rad that I know is the one indicated in the picture, for the other two something that could look like it will be ok, for the cutting lenght close to it will also be ok. Thank you | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
| Forum Liaison ![]() |
Mars, with a router you do not need to find one cutter to make your profile. Break it into sections and it becomes easy. A 3/4" bullnose bit set slightly above the center of where you want the radius will provide both the radius and the straight edge. Then make a pass with either a dish cutter bit or a cove bit for the other radius. Just like down town you are done.
__________________ Mike "Living in the D" (this means Detroit!) "It's fine to disagree with other members as long as you respect their opinions" | ||
| | #4 (permalink) | |||
| Forum Contributor ![]() |
__________________ John Schaben ![]() The problem with experience is I usually get it immediately after I need it. | |||
| | #5 (permalink) | ||
John is perfectly correct. A profile like that made using one bit will require an expensive cutter. I certainly can't think of anyone who does a router cutter like that, although I know that you can get profiles like that for larger spindle moulders (shapers). Were I making something like that I might even consider machining it as two separate profile strips and then joining them together possibly with a tongue and groove joint as that would probably be more stable. But then I have the cutters which can do that already | ||
| | #6 (permalink) | ||
Hi Mars I sure with some digging you will find the one you want they make so many routers bits, the Net opens many doors for you, just do a little bit of looking.. ![]() By the way that's a common profile on early American furniture table tops the norm..===
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos Last edited by bobj3; 10-20-2010 at 02:15 PM. | ||
| | #7 (permalink) | ||
Hi, thank you all for your help, I have been searching the web and can't find that profile, most likely it will be done with the combination of two bits | ||
Sponsored Advertisements. Register to disable this advertisement.
| | #8 (permalink) | ||||
Hi Mars Don't give up so easy, here's a link that list many of the bit sellers/makers,, Router Bits, Router Bit Accessories by Whiteside Machine Amana Tool Byrd Tool Corp. CMT Forest City Holbren LRH Enterprises Oshlun Ridge Carbide Tool Freud White Side Magnate Magnate Multi-Form bit,see what you can do with just one bit,see below in the PDF file below ======= ======== Attached Files
__________________ "It's fine to disagree with other members as long as you respect their opinions" MANY,MANY help files on John's web site http://legacy.woodshopdemos.com/menu2.htm Sommerfeld Tools ,Videos http://www.youtube.com/channel/UCT-n...RWaEpMA/videos Last edited by bobj3; 10-21-2010 at 07:35 PM. | ||||
| | #9 (permalink) | ||
| On vacation ![]() |
thank you alsp help me)) | ||
| First Benchtop Router Table, get a plate or go bare? | silentblackhat | Table-mounted Routing | 38 | 05-30-2012 02:30 AM |
| New Router my way | reible | General Routing | 20 | 11-30-2011 11:18 AM |
| So you want to buy a router table... | BobandRick | Table-mounted Routing | 39 | 08-30-2010 05:23 AM |
| Correct way to install a router bit | Goldglv | Router Bits - Types and Usage | 22 | 04-07-2010 09:46 AM |
| Bit sets - deal or not ? | dietz | Router Bits - Types and Usage | 5 | 12-27-2004 06:50 PM |
