Bit for cutting aluminum - Router Forums
post #1 of 11 (permalink) Old 10-25-2011, 04:31 AM Thread Starter
First Name: Mark
Default Bit for cutting aluminum
I'm looking for a bit that is hard enough and sharp enough to cut 1/8" aluminum. It just needs to be a straight bit. I will just be reducing the width of the flange of an aluminum channel by 1/8". The flange is 1/8" thick. The channel is 6063-T52 aluminum. Does anyone know where I can get a straight bit that can handle the job?
Thanks,
Mark
mickelsen is offline
post #2 of 11 (permalink) Old 10-25-2011, 05:59 AM
Hi Mark
I understand that most quality router bits can trim non-ferrous metals ( Aluminum, brass etc)
How much of this channel do you need to trim?
Sydney, Australia
jw2170 is offline
post #3 of 11 (permalink) Old 10-25-2011, 06:44 AM Thread Starter
First Name: Mark
Hi James,
I won't be trimming too much, about 40" total.
Mark
post #4 of 11 (permalink) Old 10-25-2011, 07:57 AM
OPG3's Avatar
First Name: Otis
Get a scrap piece of the same aluminum and try cutting it with your cheapest bit. I do not expect you to have any problems. If you do experience a problem - you've only spent $8 learning that it wouldn't work. A word of caution: everyone in the room needs to wear ear protection - not as much for hearing as for protection for hot flying shreds!
OPG3
OPG3 is offline
post #5 of 11 (permalink) Old 10-25-2011, 09:13 AM
OPG3
I agree on the ear protection... would also recommend eye protection. Both of which should be SOP anyway.
Here's a source for bit especially designed for aluminum in case you need to go that route
Aluminum Router Bits: Non-Ferrous Metal Cutting Router Bit Selection
John Schaben
jschaben is offline
post #6 of 11 (permalink) Old 10-25-2011, 10:50 AM
For aluminum I prefer to use a face shield over just safety glasses. Hot aluminum on the face is very uncomfortable.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #7 of 11 (permalink) Old 10-25-2011, 12:24 PM
First Name: pat
Something short, something carbide, something cheap. The fixtuting is critical not the cutter.
Generic tool: 1/2 shank, 1/2: FL, Carbide faced or solid, single or double flute, spiral, helix or straight.
Quillman is offline
post #8 of 11 (permalink) Old 10-31-2011, 08:36 AM
OPG3's Avatar
First Name: Otis
Whittier, CA.
Just because you can, doesn't always mean you should
Good point, James; but it is a great way to remove a beard! OPG3
OPG3 is offline
post #9 of 11 (permalink) Old 10-31-2011, 12:46 PM
Whittier, CA.
But wouldn't that leave something that resembles razor rash?
Whittier, CA.
jlord is offline
post #10 of 11 (permalink) Old 11-07-2011, 08:51 AM
OPG3's Avatar
First Name: Otis
Yes James,
The "razor rash" factor is a good reason to use the face mask! I've learned from my mistakes that hot, metal objects in my ear is not a recipe for a fun day. OPG3
OPG3 is offline
Human Verification
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
How to Make A Stand Alone Bookend Set learnexperience Jigs and Fixtures 2 08-04-2011 03:22 AM
Sears Router bit description gary smyth Jigs and Fixtures 4 07-18-2011 12:38 AM
Sears Router bit description gary smyth General Routing 1 06-30-2011 10:23 PM
