| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User | I was given some router bits by someone cleaning-out a garage. Many of them are solid cutters. Is there a simple shop test to distinguish between carbide and HSS cutters? Many thanks. |
| | #2 |
| Forum Contributer Supreme Forum King | Hi FortyFour There is a small test BUT you may not want to use it on router bits. It's a grinder test, when you grind steel the sparks will tell you what the steel is but most router bits that have carbide blades you can tell just by looking at them. And the most common router bits are HSS that's to say if they are round over and alike. Most home owners don't have the high end soild carb. bits,one bit can cost almost the same as a full HSS set. Spark test below http://en.wikipedia.org/wiki/Spark_testing_metals Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-15-2006 at 02:00 AM. |
| | #3 |
| Registered User Forum Fanatic | You can also check the weight. Carbide is heavy. Also the corner of a file will skip across carbide like it was glass. And the color of carbide is duller than the shine of HSS. About the only solid carbide cutters will be straight spiral cutters, the rest will have a piece of carbide silver soldered to a steel body of the cutter. The solder joint between the carbide and the tool body is easy to distinguish. Thanks, Chuck
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| | #4 |
| Registered User New Member | I suspect that carbide is not magnetic Bill |
| Magnate Router bits | kp91 | Tool Reviews | 2 | 07-09-2007 04:36 AM |
| tounge & groove bits | kamrx7 | General Routing | 3 | 11-21-2006 10:31 AM |
| Quality bits | RobertJR | General Routing | 5 | 04-19-2006 01:36 AM |
| New Router Bits.......... | kenadian | General Routing | 5 | 12-27-2005 07:09 AM |
| Need help deciding on bits. | ryan.s | General Routing | 8 | 03-25-2005 10:35 PM |
