Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - T-Slot bit.
Thread Tools Display Modes
Old 09-16-2006, 02:48 AM   #1
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Default T-Slot bit
I recently got a T-slot bit(like a keyhole bit only slightly larger)from MLCS. Item #6333. I got it for making T-slots in jigs and fixtures rather than using commercially availiable T-track. When I use it with BJs dado jig (see link) I can only have about 5/8" of shank in the collet. Or the collet will rub on the template guide. Total length of bit is 2", Large diameter at bottom is 3/4" x 1/8". Is this safe?
http://www.routerforums.com/attachme...router-508.jpg
Thanks, Rusty
RustyW is offline   Top - Reply with Quote
Old 09-16-2006, 09:45 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I would be uncomfortable using a bit that way, less than half the shank in the collet. How thick is BJ's jig? 1/4" is plenty thick for a jig.
Old 09-16-2006, 05:55 PM   #3
labric
Sr. Member
labric's Avatar
labric is on a distinguished road
Lightbulb
Rusty
You may find it easier and safer to clamp two straight edges to your tabletop and/or work piece, spaced the width of your router apart and centered on your slot.
This will allow you to maintain a straight cut and keep the bit at the proper depth in the collet.
Ric
Start Safe!!! Finish Safe !!!
labric is offline   Top - Reply with Quote
Old 09-16-2006, 07:28 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Rusty
With that bit (#6333) I would just use the router fence for that type of job but now for the standard key hole bit it should be fine.
The #6333 will pull out alot of chips unlike the small one.
Bj
http://www.mlcswoodworking.com/shops.../bt_keyhl.html
Bj
Old 09-17-2006, 04:05 AM   #5
RustyW
Forum Geek
RustyW's Avatar
Mike, my version of BJs dado jig is made of a left over plank of laminate flooring(about 5/16" thick). Also after setting up the jig, I first run a 3/8" straight bit which should ease some of the pressure on the bit. The brass t-guide has a barrel length of .201".
BJ, I made a new top and fence for my new table without the blue T-track. The cuts in question are to be made in the surface of the table. Once done, it will probably only be used with the fence.
Rusty
Old 09-17-2006, 07:54 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
hi Rusty
A 1/8" of in.is good as a mile when it comes to router and brass guides, I just needed to reread your post to make sure what you said.
That's to say if the router does not get tiped from one side or the other when you make the pass and because the jig if flat and the brass guide is in the slot it should stay flat to the stock and should be just fine when you make the pass.
Bj
Bj
Need help with a slot cutter set up Nickbee Router Bits - Types and Usage 1 11-26-2007 03:44 PM
Slot Cutters.... challagan Router Bits - Types and Usage 8 09-10-2006 07:54 PM
Slot Cutter or Spline cutter kimbert General Routing 3 10-20-2005 06:26 PM
router bit meeting resistance cutting a slot??? matey General Routing 3 10-03-2005 05:30 AM
slot cutter jig knuttle Jigs and Fixtures 1 12-19-2004 07:04 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
