Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - Rabbiting bits.
Thread Tools Display Modes
Old 09-16-2006, 04:19 AM   #1
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Default Rabbiting bits
My next bit purchase will probably be rabbiting bits or bit. I am finding that you can either get multiple bits or one bit w/multiple bearings to change the depth of cut.
Having never tried to remove the bearing from any of my bits. I'm wondering what you guys/gals are using?
Thanks, Rusty
RustyW is offline   Top - Reply with Quote
Old 09-16-2006, 08:49 AM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
I have used both. It's no problem to change the bearing out and I used to do it often but they are made primarily to use without a fence. It's just as easy for me to use a fence and smaller bearing and isolate the bearing and control the depth with the fence. I don't change the bit or bearing much that way. In fact I use straight cutters any more most of the time for cutting my rebates.
challagan is offline   Top - Reply with Quote
Old 09-16-2006, 09:52 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Rusty, the reason to buy a rabbiting bit is for working inside a cutout section or when freehand routing. Corey gave you good info about the fence.
Old 09-16-2006, 12:02 PM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Rusty, I have a rabbiting bit with several bearings, and it works just fine. No problem removing the bearing when I need to change the rabbit depth. Since the bit is about 1 1/14 diameter with a 1/2 inch shaft I can use it a a trimming bit. I have had two sets, one from Amana and now one from Infinity. I think the Infinitry set is a lot better. Hope this helps. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 03:36 AM
tounge & groove bits kamrx7 General Routing 3 11-21-2006 09:31 AM
Quality bits RobertJR General Routing 5 04-19-2006 12:36 AM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
router bits from oak park reds_21 General Routing 1 02-09-2005 12:59 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105
