| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User Forum Fanatic | I recently purchased this keyhole bit to make jigs and things using 1/4 hex head bolts. Although the bolts fit nicely into the slot, the head of the bolt spins freely when inside. This will work for some things but I had envisioned a slot where the bolt head was "captive". I haven't tried yet but I'm sure it will work better with 1/4" t-bolts. What t-slot or keyhole bits are you folks using and with what bolts? Michael Last edited by mpphoto; 09-17-2006 at 10:44 AM. |
| | #2 |
| Forum Contributer Supreme Forum King | HI Michael Like you I use the key hole bit most of the time for T-Slots and I use Toggle Bolts (5/16 x 4" long the norm.) and cut them to size when I need a short one like a 1 1/2" and because they are full thread they work great and all I do is grind the head on two sides to make a T-Slot bolts.. it's quick and easy to make a T-Slot bolt and it's about 1/10 the price of the standard T-Bolts from like Rockler,Plus one size on hand I can just cut off the threads and grind it quick and easy. ![]() I did get a little feed up with the hack saw so I got a little chop saw from Grizzly and put my HF grinder into to chop off the toggle bolts and other items like threaded rod and alike and I don't always use the side grinder anyway so I put it to work this way. Here's one more link from Bj for a Grizzly item, but it's at a great price and it works great for small stuff, I have a BIG 14" chop but it's a bit over kill on small fastners. 18.oo dollar chop saw.. ![]() http://www.grizzly.com/products/G8183 Just a note***when I use the key hole bit I always run it down the stock and then set it just a bit deeper and make one more pass,I like the one that's yellow, I don't recall the name right now but I get them from HomeDepot they work the best. Bj ![]()
| | #3 |
| Retired Moderator Supreme Forum King | Hey that is a cool little set up. I might have to get me one of dem! Corey |
| | #4 |
| Registered User Forum Fanatic | You've outdone yourself with that link Bj! Very sweet and useful little item. I recently decided I had need for a little setup to cut bolts and aluminum bar and angle. I was going to get a mini chop saw at Harbor Freight but I like your solution much better. Thanks! By the way, I felt the same way. Although my keyhole bit will probably work with 1/4" t-bolts these are not always available locally and have to be mail ordered. It also bothers me that they cost 5 or 6 times more than regular bolts. Michael |
| | #5 |
| Forum Contributer Supreme Forum King | I Michael Thanks,,At one time I sold fastners (Bolts & Nuts) for A & I Bolt & Nut and at that time the T-Track bolts cost 3.15ea. for 5/16-18 x 2 1/2" and if you look at one you will see how it's made ,just a flat stamped round head and it has been ground on two sides of the head to get the T-Slot fastner..., most toggle bolts are Truss Head M/S ,that's a low head type of screw with a big head, they use the same type(of die) to make the T-slot bolts and they stamp them out by the Mill.in a day and then ship them out for a zinc job. The mark up on fastners is about 800% that's to say a 1/4-20 x 3" carr. bolt cost .04ea. and you and I pay much more at the HD,Ace,etc. And the T-Bolts are much higher markup, supply and deman thing. ![]() Just a NOTE , you can save tons of money by buying toggle bolts from a fastners supply house in your town, i.e. 5/16 x 4" toggle ,should go for, (one box of 50) should be about 14.50 per 100 that makes a T-Head bolt .15 ea. in any size up to 4"...after just a little rework on you part and mind.Bj ![]() Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-17-2006 at 01:43 PM. |
| | #6 |
| Senior Moderator Supreme Forum King | Michael, the shank on the bit you posted tells you it is for 5/16" bolts. This is why your bolts are spinning in the wood. A bit for 1/4" bolts will have a 1/4" cutting shank.
| | #7 |
| Registered User Forum Fanatic | Hmmmm. Well Mike, I feel a little silly. Yup... In my defense I tried a 5/16 bolt and it was tight. I just tried again and it fit perfect. The difference; the first time I tried a lag bolt that wasn't threaded all the way up and the fit was no good. This time I tried a threaded hex head bolt and viola! Perfect fit and the head doesn't spin. So the moral of the story is that a Whiteside #3050 Keyhole bit works well with 5/16" hex head bolts for making jigs that require t-slots. Thanks Mike ![]() Anyone else using keyhole or t-slot bits? What hardware are you using with it? Michael |
| new omnijig user with a question | dracjm | Introductions | 1 | 06-29-2008 03:09 PM |
| DC Question | angus | Lobby | 3 | 03-31-2008 08:29 PM |
| Where do I post this type of question? | RouterFool | Introductions | 1 | 03-30-2006 09:54 PM |
| craftman router question | tsbrewers | Table-mounted Routing | 7 | 05-16-2005 06:54 PM |
| Question: Sub Base Plate and guide bushings | trap | General Routing | 3 | 04-17-2005 08:25 PM |
