Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 10-02-2006, 12:20 AM   #1
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Default Safe Speed of 1 5/8" dia. bit...?
I just received a 45* Chamfer bit that is 1 5/8" dia. and 1.25" high.
It is a very heavy bit... heavier than I have ever used (yes, I'm new to this) ...
I'm curious, is it safe to run it at full speed?
Should I slow it down? If so, to what speed to be safe?
Thank you.
Joe Lyddon is offline   Top - Reply with Quote
Old 10-02-2006, 12:42 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
You should have no problems with this bit running at full speed. Reduced speeds normally start around 2" diameter bits or when working with very hard wood. A more complex cut would also qualify for a slower speed at 1-1/2" diameter.
Old 10-02-2006, 10:17 AM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
What I recommend, is turn your router speed down all the way then make your pass.
The speed of the bit can get to you and with time you will feel better when you run the bit at a higher speed,the bit doesn't need to run at 15,000 rpm to 18,000 rpm to do a good job, just take it slow and easy and the bit will do the work for you without burning the stock or the bit.
The BIG bits can make you not want to use them if you run them at high speed.
Something about a chunk of steel spining at 15,000 rpm. and you need to put your hands by it or close to it.
The reel key is your ears, listen to what the bit is telling you, they do have a voice so to speak, they will tell you I need more speed or less speed please.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Variable Speed vs. Fixed Speed Phillip K General Routing 24 07-12-2008 11:29 PM
How do you tell a router's speed??? allthunbs Table-mounted Routing 11 07-07-2008 04:08 PM
rule of thumb for variable speed? rprice54 General Routing 3 01-11-2006 06:50 PM
Router speed controls RustyW Starting Off 1 12-29-2005 07:42 AM
variable speed routing Dean VV Table-mounted Routing 3 03-23-2005 11:12 AM
