Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 10-22-2006, 09:33 AM   #1
arkwood
Member
arkwood is on a distinguished road
Default Panel raising bits
Hi, I am a new member and may be repeating a question. I am looking for a good ogee raised panel bit. I bought a cheap set from Harbor Freight for learning process. I am looking at Whiteside. I want a good router bit, but need to keep my cost to a minimum while getting quality.
Also, would it be beneficial to go with a three wing. Would a back cutter be a good idea. Have not seen any three cutter bits with back cutter. Info appreciated. Jerry
arkwood is offline   Top - Reply with Quote
Old 10-22-2006, 10:28 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Jerry
You didn't say what type of router you have or if it's a 3 HP or more.
The big panel bits take power to turn and you need to run them at slow speeds.( 8,000 to 10,000 rpm the norm)
"Would a back cutter be a good idea. Have not seen any three cutter bits"= see the link below and the back cutter are great but you must take care with them because you are trapping the wood so to speak.
http://www.mlcswoodworking.com/shops...wing_rp_anchor
I do recommend making the jig below if you are low on power that's to say
1 1/2 HP to 2 1/2 HP router and using a rabbit bit for the back cutter or you can buy a back cutter bit for about 20.oo from the same.see MLCS.
http://www.routerforums.com/jigs-fix...uick-easy.html
Plus the one below
http://www.routerforums.com/show-n-t...4-new-toy.html
Undercutter Bits, MLCS bit part number #8679
The 2 flute, carbide tipped undercutter bit, with totally enclosed ball bearing guide is designed to relieve the back of a raised panel with a 1/8" radius shaped cut.
This will let the panel sit flush with reference to the doorframe.
It also cuts the panel tongue to 1/4" thick when working with 3/4" stock and certain panel shapes.
http://www.mlcswoodworking.com/shops.../raisvert.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-22-2006, 11:02 PM   #3
arkwood
Member
Thanks for the info. I have the PC 7518 in my table, so I have ample power and have
been running the big panel bit from HF at a slow speed. Think I want a three cutter bit for smoother cuts and was not sure about getting a back cutter. Can only find two wing bits with back cutters. Also want to get one that will last when I make the investment.
Thanks again for replying. Jerry
Old 10-23-2006, 02:29 AM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Jerry, Whiteside is consistantly the top rated bit in tests and by guys wearing plaid shirts on PBS woodworking shows. Isn't it nice to be able to take pride in an American made product as being the best in the world?
Old 10-24-2006, 10:11 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Jerry
Just a note
The Vertical bit can run at higher speeds or to say at 18,ooo rpm unlike the big panel bits. the faster the bit turns the better the finish/cut and they are a bit safer to use in the jig or the vertical (Horz.) router table.
I have CMT and MLCS vertical bits and the CMT bits are a bit better than the MLCS that's to say they are sharper and will last longer and they are coated with teflon to keep them running smooth.
But this is just my 2 cents...
Here's a quick test,,,, cut two panels the same size one out of hardwood and one out of part.board (chip board) or MDF run two sides on the hardwood on the big panel bit and the other two sides with the vertical bit at high speed you will see the vertical didn't rip stock out it and made a nice smooth finish on the chip.board.
I know you will say but I don't use chip.board or MDF for door panels but you can with the vertical bits.(for painted panels)
Just one more test,,,,,,make a panel that's 3" x 4" or smaller that can be a bit tickey when you use the big panel bits or the small panel bits ( 2 1/2" dia.) but with the vertical bit it's duck soup and you get to keep all your fingers when your done making it. (small panels for a clock or a box or ??? )
With this bit set (below) you can make 2 3/4" sq. panels but they are ticky to make and you must know how to run the stock by the panel bit, the high point on the panel is only 1/2" sq. in the center of the panel but again with the vertical bit it's duck soup to make a very small panel(s).
3-Piece Junior Raised Panel Set
http://www.sommerfeldtools.com/products.asp?id=19
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-07-2006, 01:12 AM   #6
sawstop
Member
sawstop's Avatar
sawstop is on a distinguished road
Another manufacture of router bits is Freud
With a unique 4 cutter system
They come in a custom box with a sold wood base & clear protective lid.
The design makes doing the math for your raised panels, Stiles, & Rails extremely easy.
See here.
http://www.freud.ca/English/Pages/Re...DFs/RPMath.pdf
http://www.freud.ca/English/Pages/Re...RPDenglish.pdf
http://www.freud.ca/English/Pages/Bits/Bits.html
http://www.freud.ca/English/Pages/Bi...ackcutter.html
http://www.freudtools.com/woodworker...d_Panel_1.html
I have had excellent results with a finish that you could get away with out sanding if you had to but I still sand.
One can never have too many Tools or Jigs for woodworking
sawstop is offline   Top - Reply with Quote
Bits for the Oak Park raised panel system Mike Router Bits - Types and Usage 15 11-10-2008 10:35 PM
Raise panel bits, router power davewest Router Bits - Types and Usage 3 02-23-2008 01:36 AM
raised panel router bits Dave2 Starting Off 7 03-30-2007 11:13 AM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 10:47 AM
Raised Panel Router Bits Dan Butler Tools and Woodworking 3 11-20-2004 01:30 PM
