Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 10-26-2006, 10:42 AM   #1
mapletree
New Member
mapletree is on a distinguished road
Default 60 degree chamfer bit
Does anyone make a 60 degree chamfer bit? I bevel both sides of 1" plastic leaving about 1/8" flat in the middle. I made a bit and use it in a milling machine but it is not a good set up even though it does get the job done.
Dick
mapletree is offline   Top - Reply with Quote
Old 10-26-2006, 11:22 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Dick
You may want to check out the links below, they may work for you.
60° Lettering Bits
http://www.sommerfeldtools.com/list.asp?d=66&p=1
http://www.mlcswoodworking.com/shops...s/bt_sign.html
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-30-2006, 12:22 PM   #3
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
Dick
Dick,
Do you want 60° angle from the shank or from the the flat surface of the material you are cutting? A 30° chamfer bit like the Freud 40-206 is measured relative to the shank. If you need the angle in the other plane you may be able to run the material on edge.
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 10-30-2006, 02:05 PM   #4
mapletree
New Member
It is 60 degrees from the shank. The plastic has irregular shapes and is wide. Good idea though.
Old 11-01-2006, 04:16 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Dick
Just one more place to get the bits from
http://pricecutter.com/product.asp?pn=P13-2111
http://pricecutter.com/product.asp?pn=P13-2129
http://pricecutter.com/product.asp_Q_pn_E_P13%2D2106
They are a bit high in price (on some of the items) BUT they do have the hard to find router bits .
Like this one ▼
http://pricecutter.com/product.asp?pn=P13-2242
http://pricecutter.com/category.asp?c=243788&c2c=ln
NOTE***NOTE***
If you have a Oak-Park Box Jig take a real hard look at this jig
The BIT is On the Right Hand Side of the slide guide ... looks like Bob & Ricks, almost... hummmm.....
Box Joint Jig w/Push Block
http://pricecutter.com/product.asp_Q...r%3EPush+Block
NOTE****
Any one have this jig ▼ ▼,,????, I sure would like to see a snapshot of the backside of the push block.... thanks.
Bj
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-02-2006, 08:36 AM   #6
Charles M
Forum Fanatic
Charles M's Avatar
If you can get by with 64.5° you can use this 99-511:
and replace the bearing with one that is 1-1/8".
Charles M
Freud America, Inc.
Old 11-02-2006, 11:58 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Charles,that's a great work around BUT
I could not find a bearing ( 1 1/8" O.D.) that would fit the bit, do you have a part number for the bearing. ? and a list price for it ...
THANKS
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-02-2006, 04:11 PM   #8
Charles M
Forum Fanatic
Charles M's Avatar
Bj,
Freud item# is 62-148 and list price is $7.60. This bearing is included in our 7 bearing Multi-Rabbet bit sets or can be special ordered from a Freud dealer to get it separately.
Charles M
Freud America, Inc.
Old 11-02-2006, 06:44 PM   #9
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Charles
http://www.acetoolonline.com/Product...ode=FRE-62-148
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
what chamfer bit for miters on 3/4" kleptic Router Bits - Types and Usage 4 06-20-2008 11:38 PM
How to cut a large chamfer? tstellman Table-mounted Routing 1 06-01-2008 11:34 PM
45 Degree Lock Miter bit mjeisenbaugh Router Bits - Types and Usage 6 03-28-2008 08:09 AM
Perfect 22.5 degree miter Kristin D Tools and Woodworking 11 02-26-2008 06:59 PM
Carvewright 45 Degree edges dadsalmon General Routing 14 07-10-2007 10:43 AM
