Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - Rail and Stile alignment....HELP.
Thread Tools Display Modes
Old 10-29-2006, 09:08 PM   #1
arkwood
Member
arkwood is on a distinguished road
Default Rail and Stile alignment....HELP
First, I did download the instructions from MLCS and found my rail and stile, ogee. I am about to pull what little hair I have left out. I am not sure which bit to move. Holding rail in right hand and stile in left, here is what I have.
Stile has what I will refer to as male ogee. It is thicker top to bottom and will not fit in the female ogee on rail end. Rail end seems to be about 1/8 inch lower than top of stile and of course this makes it about the same below the bottom of the stile. I am guessing that the smaller female oggee on rail end had to be the right size. Do I need to adjust the stile bit. Hope this makes sense to someone or you can point me in the right direction. Will keep patterns when I get it right.
arkwood is offline   Top - Reply with Quote
Old 10-29-2006, 09:14 PM   #2
deck99
Sr. Member
deck99 is on a distinguished road
http://www.newwoodworker.com/ralstilbitset.html
deck99 is offline   Top - Reply with Quote
Old 10-29-2006, 10:23 PM   #3
arkwood
Member
Thanks a million, very informative . I think I can handle that, would have saved me a bunch of time and misery. Thanks again
Old 10-30-2006, 06:18 AM   #4
del schisler
Forum Geek
del schisler is on a distinguished road
here is maybe a better set up 1 single bit to do both rail and stile I bought mine i thank from Price cutter But check out the price on other supplyer's 1 bit save's time for me Cut the stile on all Than lower the bit for the rail ends cut Their is a sheet that tell's how to get it right Here is a pic of the single bit http://www.mlcswoodworking.com/shops.../bt_stack.html
del schisler
del schisler is offline   Top - Reply with Quote
Old 10-30-2006, 06:23 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi arkwood
Here's quick tip how to align the bits to make that door frame quick and easy.
Most of the good Rail and Stile bits come as a matched set,that's to say they are made at the same time at the Fac. as a pair.
But you need to use them that way, 1st. put in a grommet or a faucet washer in your router collet, it must be the right size for your collet, so it can't move around inside the collet and stay in place in the bottom of the collet.
You can get a small box of them at just about any hardware store.
Once you put the (grommet) in the collet you are set,now put in the bit for the cope cut, set it so you have about 1/8" on the lip of the Ogee, then cut your stock to make the rails, make two of the rails at one time, that's to say use a 5" wide board and then rip it in 1/2 to make the 2 rails,now put in the patten bit (stile bit) do it the same way 5" stock, the bit should be right on when you put it in the router (matched set) now make a Small (1/16" long) cut to check the alignment, if it's OK run the stock by the bit and do the same thing, take it to your saw and rip in 1/2.
Your done, you should have 4 parts that are all the same and just waiting for the panel.
Make your rails a bit long so you can get your 1/2" overlay,you can always cut them off you just can add to them
Bj
Old 11-13-2006, 10:43 PM   #6
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Bj,
I'm sure glad your here. I've found that clicking your name and searching your posts, will reveal more and better tips and tricks than a whole stack of woodworking books.
I use a sled for cope cuts so I need to adjust height when changing bits. But I'm building a mantle clock and wanted to use my r&s bits to make the door. Problem was, the frame was only going to be 1 1/2" wide. I was trying to think of a safe way to do it when I saw this post. Ripping the parts in half after routing is a simple solution that had not crossed my mind.
Thanks, Rusty
RustyW is offline   Top - Reply with Quote
Old 11-14-2006, 09:06 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You're Welcome Rusty
I'm glad it helped, I also use it to get the parts of the door to match (wood grain thing) I will glue up stock to match sometimes and make 4 or 5 doors that are all the same wood that way,plus you don't need to use the sled sometimes because the stock is wide and you can make all the cope cuts at one time and then rip them to size.
Then make a male /female jig to put on the patten cut that can be a bit tricky on
1 1/2" wide stock.
Plastic push block that has a female (patten) screwed to the block so it will hold it down to the table and let you push it by the bit safe and a small 2 x 4 block to hold it to the fence.
Like the one below ▼
Note,,,, the cut outs can be 3/4" deep but make two or three blocks they are nice to have on hand.
Bj
rail-stile-alignment-help-block.gif  rail-stile-alignment-help-6168.jpg  rail-stile-alignment-help-6169.jpg  rail-stile-alignment-help-6170.jpg  rail-stile-alignment-help-6171.jpg
Old 01-09-2007, 10:38 PM   #8
dlgdoo
New Member
dlgdoo is on a distinguished road
Just set them up one time. I bought a matched set of rail and stile bits from MLCS. I noticed in the magazine they had "set-up" blocks. I figured I could make my own. So first time I used my bits, when I got them aligned perfect, I took 2 square scrap pieces of MDF. I ran one through to make the stile cut, then used the other one to make the cope or rail cut. The MDF holds up well, I stored them right next to the bits, and I know it is a perfect 3/4 inch. Each time I used my bits I just use my own set-up blocks, it is not always perfect right off, but it saves me a lot of time.
dlgdoo is offline   Top - Reply with Quote
Old 01-10-2007, 11:07 AM   #9
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi digdoo
It can be tricky to set up for the Rail and Stile even when you have the setup blocks, here's a trick I use all the time.
Most R & S bit sets are matched sets, that's to say the cutters are in the same spot on the router bit shank, from the bottom.
Put a rubber grommet in the router collet ,at the base of the collet,this will hold the bits at the same height,now if you use a sled ,that is 1/4" thick the norm just slip a brass setup bar under the cutter, to raise it by 1/4" the norm when you used the router sled.
Your stock can be 1/2" to 3/4" and it will come out right on the button every time.
The grommet must be in tight, in the base of the collet so it can't move or drop down when you put the bit in the chuck.
You can also use a rubber faucet washer,that you can get from a hardware store in a repair the kits for about 3.oo dollars for 20 or so.
Not all router chucks are the same size,ID so you will need to play with it just a bit to get the right size,it should be a tap fit,that's to say tap it in the collet so it's flush on the bottom of the collet.
Bj
Hi all -- rail and stile bit and 1/2" collet help! Bryan Introductions 14 11-25-2007 11:40 PM
Stile & Rail Bit DougO Router Bits - Types and Usage 7 07-11-2007 08:42 PM
Rail & Stile Dilemna sameerallidina@shaw.ca Table-mounted Routing 3 01-22-2007 02:49 PM
One piece stile & rail bit tsringcutter Table-mounted Routing 3 01-10-2006 08:44 PM
Stile and Rail setup? fitz Jigs and Fixtures 1 03-26-2005 07:53 AM
