Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 11-08-2006, 11:02 AM   #1
ATLAS 2556
Member
ATLAS 2556 is on a distinguished road
Default stacked or matched ?
What do u guy's recomend.......stacked or matched rail and stile bit
thanks tom
ATLAS 2556 is offline   Top - Reply with Quote
Old 11-08-2006, 11:20 AM   #2
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
Tom,
For the stacked there are three different types. One requires that you run one piece face up and the mating cut face down, the second runs both face up and the last (like the Freud offerings) runs both face down. For the first two you have more possibility for surface mismatch on the front of the doors. Also, with the first type the groove part is used for both cuts so it will wear faster.
Comparing to the matched sets, the stacked type can not be shimmed so once they are sharpened the fit of the joint will not be as tight.
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 11-08-2006, 11:20 AM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Tom
I always recomend matched set, some people call a stacked bit as a one cutter that you just move up or down to get the job done.(just reset the height)
I see Bob and Rick like to use this type of bit and I'm not to sure why ,it may be because the Oak-Park setup you need to remove the fence to replace the bit .
If you use the matched set all you need to do is drop in the other cutter and the height should be dead on, that's if you use the rubber grommet in the router locking device.
The grommet lets/keeps the bit at the same height so you can make rail and stiles that come out true every time with little or no sanding them.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-08-2006, 11:29 AM   #4
ATLAS 2556
Member
Thanks bj Tom,,,
Old 11-08-2006, 11:30 AM   #5
ATLAS 2556
Member
Thank u Tom ........Tom lol
Stacked Slot Cutter Set & Intro.......... richinva Router Bits - Types and Usage 5 02-03-2008 09:05 AM
