| | #1 |
| Registered User New Member | I have to make a series of slots in 3/4 " material (pine) about 5-1/2 long all way through. I plan on a 3/4 " bit however can this be done in one slow pass or two? ![]() |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Grandasworkshop I don't see why not BUT it's one of those things you need to just try out ![]() If your bit is new and sharp it should be duck soup but if not it will take a pass or two. Pine is soft but will dull the bit real quick with build up of pine pitch. A good spray Teflon base bit lub or a good bit cleaning will help with Pine. ![]() http://www.mailwareweb.com/sommerfel...2d2oz&d=99&b=2 http://www.mailwareweb.com/sommerfel...d16oz&d=99&b=1 Bj ![]()
__________________ Bj |
| | #3 |
| Senior Moderator Supreme Forum King | Two passes in pine should make for a nice clean cut. For hardwoods stick to a 1/4" removed in a single pass for quality.
__________________ Mike |
| | #4 |
| Registered User New Member | Thanks so much.I did not want to chance any thing like that in case it grabs and pulls fingers in |
| | #5 |
| Forum Contributer Supreme Forum King | Hi jj101 May I Recommend using one of the items below,they will help you keep all your parts (fingers) ![]() http://www.rockler.com/product.cfm?p...=push%20blocks http://www.rockler.com/product.cfm?p...=push%20blocks http://www.rockler.com/product.cfm?page=10395 Bj ![]()
__________________ Bj Last edited by bobj3; 12-01-2006 at 09:38 AM. |
| Cutting boards for gifts.... | gad5264 | Project Plans and How To | 13 | 10-19-2007 11:13 AM |
| Dovetail Depth of Cut | Sherwood | Portable Routing | 5 | 09-15-2007 10:28 AM |
| Sloppy depth settings!! | Birch | General Routing | 4 | 04-06-2007 07:13 AM |
| Cutting dados on a router table | paulcomi | Table-mounted Routing | 6 | 08-05-2006 10:52 PM |
| pc 890 series depth adjustment | rabuckner | General Routing | 4 | 04-10-2005 01:20 PM |
