| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #11 |
| Senior Moderator Supreme Forum King | Rusty, the key to understanding up cut and down cut is this: do you want to pull the waste away from the cut? Most of the time the answer is yes. Table mounting means the direction is reversed but still pulling the waste away from your cut. This is why the up cut is the most popular of the two choices. The down cut bit pushes the waste into the cut. This is used to help prevent tear out on the top surface. A good example would be on veneered plywood to keep the veneer from pulling away from the ply. So up cut means away from the closest wood surface to the router and down is towards that surface.
| | #12 | |
| Banned Supreme Forum King | Quote:
Downcut moves the chips away from the router... IMHO | |
| | #13 |
| Forum Contributer Supreme Forum King | Just a show and tell for spiral bits ▼ Hand held routers,the bit rotate clockwise, routers mounted in a table, the bit rotate counter clockwise. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-14-2007 at 10:02 AM. |
| | #14 |
| Registered User New Member | Just take no notice of the arrows, you can view them either way. |
| Box joint - first attempt | Dennis Davis | Show N' Tell | 5 | 02-09-2008 10:01 PM |
| Incra half blind joint | S Bolton | Jigs and Fixtures | 7 | 10-23-2007 02:38 PM |
| Hidden Mitre Joint | DougO | Router Bits - Types and Usage | 9 | 10-21-2007 12:42 AM |
| My first finger joint box | simplenik | Table-mounted Routing | 6 | 06-24-2007 09:52 AM |
| My first ever Finger (box) joint | simplenik | Table-mounted Routing | 19 | 06-23-2007 10:53 AM |
