Go Back   Router Forums > Routers > Router Bits - Types and Usage
Thread Tools Display Modes
Old 12-10-2006, 03:29 AM   #1
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Default Box Joint Jig
I am planning to build a box joint jig to be used on my router table. I usually see these used with a solid carbide spiral bit. I've never owned one. Is it practicle to use a standard straight bit? What is the advantage of the spiral bit?
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
Old 12-10-2006, 04:37 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Rusty
"What is the advantage of the spiral bit?" >>
"Top quality micrograin solid carbide. Will cut faster, smoother and stays sharper longer. Produces a very clean, fast and accurate cut with minimal chatter."
"Is it practicle to use a standard straight bit?" >>
Yes and No , in soft woods it's OK the norm but it's hard on the bit in hardwood and may take a pass or two to get what you want. i.e. 1/8" and 1/4" bits,and 3/8" most max out at 3/4" deep or less.
http://www.mlcswoodworking.com/shops...olid_sets.html
Bj
Bj
Old 12-10-2006, 08:28 AM   #3
kp91
Forum King
kp91's Avatar
Rusty,
Using a plain straight bit will work, but you MUST have a back-up piece behind the cut or you WILL blow out some of your cuts. (usually the very last one in the most expensive piece of wood.....) A flush trim bit works a little better, since it has a bit of a slicing cut in stead of a "slapping" the wood as it comes in and out of the cut.
1 John 1:9
Old 12-10-2006, 10:40 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Doug
I love to find new ways to make box joints ,can you Please tell me how You use a flush trim bit to put in box joints,that's a new one for me.
Do you have round ends on the top of the box joint ?
I can see how you can use a template flat on the router table and push the stock into the Flush Trim Router Bit template but the bit will put in round ends.
That would be a nice touch on some boxes,log cabin effect
Attn: Doug
Here's a jig to help with Blow Out of the slot.
http://www.routerforums.com/jigs-fix...ush-block.html
Bj
Bj
Old 12-10-2006, 01:26 PM   #5
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
Ha? flush trim bit for box joints?
you can only use bottom bearing bit with a template provided the bearing is 5/8 and the router bit is 1/2. in an esence instead of using a 5/8 guide like a keller router bits which are all bottom bearing. flush trim bits have the same size router bit as the bearing.
Router is still my name is offline   Top - Reply with Quote
Old 12-10-2006, 04:09 PM   #6
kp91
Forum King
kp91's Avatar
Using a standard box joint jig using a Pattern bit (instead of a spiral) works better than using a standard box joint jig just using a straight bit. Sorry if I confused anyone by saying flush trim. My Oldham bits have a little rake, my el cheapo grizzly pattern bits do not.
1 John 1:9
Old 12-10-2006, 06:21 PM   #7
Forum King
Hi Doug, me and Bj though maybe we missed out on a box joint technique
I've always used a Super sharp Straight bit for box joints with no problem. but if they're slightly dull, then you may get some tear. it all depends on wood also. I've never used a spiral on box joints due to price. for a price of one spiral bit, I can get 3 new CMT straight bits ( on sale)
Old 12-13-2006, 01:27 PM   #8
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Hi highly recommend the Oak Park spacer jigs that they use on the Router Workshop...
http://us.oak-park.com/catalogue.html?list=boxj--
There is a Discount code to get 10% more off sale prices... super good deal on the set of three...
I just got the set not too long ago... they work great and SIMPLE!!
Joe Lyddon is offline   Top - Reply with Quote
Old 12-23-2006, 04:03 AM   #9
RustyW
Forum Geek
RustyW's Avatar
Thanks for the replies. When I joined this forum I read that the "only dumd question is the one not asked". So here goes...The jig I'm planning to build will be on top of my router table with the bit sticking up thru the table(simular to the oak-park spacer fence). Do I want upcut or downcut bits for this?
Rusty
Old 12-23-2006, 08:16 AM   #10
Hamlin
Supreme Forum King
I believe that Oak Park sells only "upcut" spiral cutters. I have the box joint jigs with the 1/4, 3/8 & 1/2 cutters, all are upcut. I have no problems with them.
Ken
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Box joint - first attempt Dennis Davis Show N' Tell 5 02-09-2008 09:01 PM
Incra half blind joint S Bolton Jigs and Fixtures 7 10-23-2007 01:38 PM
Hidden Mitre Joint DougO Router Bits - Types and Usage 9 10-20-2007 11:42 PM
My first finger joint box simplenik Table-mounted Routing 6 06-24-2007 08:52 AM
My first ever Finger (box) joint simplenik Table-mounted Routing 19 06-23-2007 09:53 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
