Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - Dovetails In Plywood.
Thread Tools Display Modes
Old 12-16-2006, 01:45 PM   #1
rmaxa
Forum King
rmaxa's Avatar
rmaxa is on a distinguished road
Default Dovetails In Plywood
I could not find any decision on making dovetail joins on ¾” birch plywood in the forum. I’m building a train table with drawers for my grandson, and wanted to make it kid friendly. I used my dovetail jig on the first drawer, and I got lots of tear out. Is there a special bit that would reduce the tear out on plywood or should I reduce the speed? I would appreciate any help I could get. I don’t use plywood for many of my projects
Rolf
"I love it when a plan comes together"
Hannibal Smith
rmaxa is offline   Top - Reply with Quote
Old 12-16-2006, 02:00 PM   #2
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
Hi rmaxa,
Making dovetail joints in plywood is more prone to tear outs than solid woods.
There are few things you can do to reduce or eliminate the TO’s. Use a sharp/new DC spiral bit. And also use a front and back backing board. If you don’t have a DC spiral bit and are using straight bit ( must be sharp), you have to use a front and back backing board for sure. Depending on you dovetail jig set up. Some jigs you only have to use one board in front for tear outs. The speed of the bit should be set to the size of the router bit. If it’s ½ inch bit or smaller then use a max speed.
Router is still my name is offline   Top - Reply with Quote
Old 12-16-2006, 02:27 PM   #3
rmaxa
Forum King
rmaxa's Avatar
Thanks for you help! I have been using a 1/2" dovetail bit. I should try using a spiral bit.
Thanks again for your help.
Rolf
Hannibal Smith
Old 12-16-2006, 04:22 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi RMaxa
If you are using a standard dovetail jig you will need to used a dovetail bit
You can't get away without using it , On some jigs you can use a straight bit on one side but you must use a dovetail on the other side.
Give this a try, it works for me, take some double sided carpet tape and stick on some 1/8" or 1/4" MDF stock on both sides of the plywood, it only needs to be as wide as the dovetails or just a bit longer, then clamp it in the jig and put in the dovetails, you will still get just a little rip out but the MDF will at as a chip breaker and help hold the plywood from pulling out.
NOTE**** don't forget to add a 1/8" or 1/4" to your setting on the jig to off set the MDF stock.
Note**** if you are using blind dovetails you only need the MDF on one side (inside of the box cut) if you are making the side(s) and the front/back at the same time in the jig) this way you don't need to change your jig setting but the MDF must be the same size as "wide) as the box/drawer , but go slow on the ends and made very small cuts, out side 1st then move in.
You will also need to drop the bit down by 1/8" or 1/4" so the joint will fit right.
Hope this helps
Bj
Bj
Old 12-16-2006, 05:44 PM   #5
Forum King
You can use the spiral on the tail side as Bj said.
Old 12-19-2006, 07:10 PM   #6
rmaxa
Forum King
rmaxa's Avatar
Thanks to both your answers.
BJ, I'm making a blind dovetail, I'll give your solution a try. Thanks
Rolf
Hannibal Smith
Old 12-19-2006, 10:00 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You're Welcome for my small part RMaxa
Please post a snapshot after you give it a try, I'm sure the other members would like to see how it came out for you
Bj
Bj
Problem Rabbeting Plywood JDługosz Portable Routing 25 01-14-2008 12:56 PM
Dovetails - more or less - opinion Donzoid General Routing 4 11-27-2007 01:02 PM
Sliding dovetails for cabinet constuction? Drugstore Cowboy Tools and Woodworking 18 07-08-2007 04:14 PM
through vs blind dovetails zxxer12 General Routing 4 03-02-2005 12:36 PM
Sliding Dovetails scrollwolf Table-mounted Routing 2 09-12-2004 09:59 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
