| | #1 |
| Retired Moderator Supreme Forum King | I was looking over the instructions with my Gifkin's jig and there are instructions to make a box. What caught my eye was his mentioning of a rebate cutter that is used with the box and joints fitted together would be used on the table to run around the inside of the box to groove for a bottom or top or both. This seems to solve alot of the problems we encounter when using these joints that don't allow us to just slot each board as the slots are visible when assembled. This has a bearing on it and keeps it from piercing thru the box sides. Here is a pic of the cutter, it is the second cutter in the photo: ![]() Anybody know if there is a cutter like this avialable in the states? Pretty handy little item it looks like! Corey |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Corey Looks almost like a under cut floor bit. Take a look at the links below. 149-1612B Bearing,Floor Rabbet Undercutter & Floating Lettering Bits http://www.eagleamerica.com/product.asp?pn=149-1202B 190-2535 2-Piece Tongue & Groove Flooring Sets http://www.eagleamerica.com/product.asp?pn=190-2412 Bj ![]()
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Floating Mortise & Tenon: A strong and Silent Joint |
| | #3 |
| Retired Moderator Supreme Forum King | Thanks Bob! That Eagle bit looks like it would work with a 1/8 heigth of cutter and depth of cut. I wonder if the shank is long enough at 1 7/8 to get up to cut a box a 1/4 to 3/8 above the bottom of the box? You think this would work on the table and just run it around the inside of the box like that safely? Corey |
| | #4 | |
| Forum Contributer Supreme Forum King | Quote:
Yep I think so , plus you can use it for offsets letters (3D type) that would look neat also...on top of a box or sign.The only draw back I can see, the box needs to be taped real tight b/4 you run the bit inside of the box,and then remove the tape so you can take it down and put in the base or top in. The Bit would almost eliminate the error that I do all the time, going to far with slot or in the wrong spot and it shows on the outside of the box. And I call myself dumb shit ,you did it again. LOL ![]() Bj ![]()
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Floating Mortise & Tenon: A strong and Silent Joint | |
| | #5 | |
| Retired Moderator Supreme Forum King | Quote:
Corey | |
| | #6 |
| Senior Moderator Supreme Forum King | Corey, some additional info that might be useful. Whiteside offers many bits that use a 3/16" ID bearing. You can purchase their #1955 multi-rabbiting bit set and have a complete assortment of bearings up to 1-3/8" OD. The 8 choices of bearing size allows for a wide variety of changes with your other Whiteside bits, such as their slot cutting bits.
__________________ Mike |
| | #7 |
| Retired Moderator Supreme Forum King | Thanks Mike. The problem with using rabbeting bit sets is that the cutters are all too bit meaning that they are two tall. In order to cut the slot all the way around the box on the inside while assembled without going thru the joints the cut would need to max out at 1/8 to 3/16 high and deep. I don't know if I could control the slot down to that size on a slotting cutter either. Would have to be a big bearing to do so I think. Corey |
| | #8 |
| Retired Moderator Supreme Forum King | I stand corrected Mike. I found that set, they have both a 1/8 and 3/16 cutter that would work and also a slot cutter. Several options avaiable, these are actually cheaper than the Eagle bit mentioned above. Corey |
| | #9 |
| Retired Moderator Supreme Forum King | This is the same cutter that I was speaking of that Roger Gifkin uses. Avaialble from Leigh Valley Tool. http://www.leevalley.com/wood/page.a...168,46176&ap=1 Also a good way to safely to the operation. http://www.leevalley.com/shopping/In...s.aspx?p=47839 Not a bad price either! Corey Last edited by challagan; 01-31-2007 at 07:01 PM. |
| Need help with a slot cutter set up | Nickbee | Router Bits - Types and Usage | 1 | 11-26-2007 03:44 PM |
| Special road trip | Mike | Lobby | 0 | 09-07-2007 11:26 PM |
| Slot Cutter or Spline cutter | kimbert | General Routing | 3 | 10-20-2005 06:26 PM |
| need special router bit | mdd94 | Tools and Woodworking | 1 | 02-25-2005 01:26 AM |
| Where to find twin 3/16" slot cutter. | Al Miller | Tools and Woodworking | 5 | 11-17-2004 07:05 PM |
