| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Registered User New Member | Need advice. I would like to: 1. Rabbet picture frames once assembled. 2. would like to plunge route using an oval template to make an opening in material ,leaving an irregular outer border but a clean oval on the inside. Question: What bits do I need to purchase to get the job done? |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Shopguy The bit below works great for picture frames . But I not to sure what you mean by saying "leaving an irregular outer border" They make many bits that will do this job. ![]() Picture Frame Rabbet Bits 2 flute, carbide tipped bits with totally enclosed ball bearings. Designed for making custom picture frames or mirrors. The double stepped rabbet will cut either a 1/8" x 3/8" or 1/4" x 3/8" rabbet for your glass or mirror, and an additional 3/8" x 3/8" rabbet for your artwork and backing board. Use for 1” or larger stock. http://www.mlcswoodworking.com/shops...ram_rab_anchor Use this one to plunge in and cut the frame out http://www.mlcswoodworking.com/shops...al_down_anchor You can use this type on bit to plunge on the out side of the frame and then use the carb. downcut with a brass guiide to to remove the outside of the frame. Faux Raised Panel Bits http://www.mlcswoodworking.com/shops.../bt_groov.html Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-11-2007 at 09:16 PM. |
| | #3 |
| Senior Moderator Supreme Forum King | Any plunge bits can be used with guide bushings inside templates. This will allow you to create your ovals not effected by the frame shape.
| Magnate Router bits | kp91 | Tool Reviews | 2 | 07-09-2007 04:36 AM |
| Basic Router Bits | DONALD | General Routing | 13 | 02-21-2006 08:42 PM |
| Need help deciding on bits. | ryan.s | General Routing | 8 | 03-25-2005 10:35 PM |
| router bits from oak park | reds_21 | General Routing | 1 | 02-09-2005 01:59 PM |
| sharpening bits..... | reible | General Routing | 4 | 09-19-2004 10:34 AM |
