Routing a recess for a patch - Router Forums
post #1 of 13 (permalink) Old 01-27-2013, 06:28 AM Thread Starter
Hello everyone, This is a great site. I have been reading it for days.
I am working on a project and I am trying to figure out the best way to execute it. Basically, I am dealing with a piece of maple that has been damaged. The area is about 4"x6". 3 sides meet seams in the manufacture, one is an outer edge with a 1/8" round over.
My plan has been to repair the damage, then cut the entire 4"x6" area to the seams and inlay a 1/8" thick piece of maple. The 3 sides will meet seams, the fourth will be on the end, partially concealed by the roundover.
I have purchased the 1/8" maple, which is planed flat on all 4 sides. Now I need to know the best way to create the recess. Will a straight bit leave me a square enough edge to but the patch in? Or should I go with a mortise bit?
I appreciate your time!
jimshine is offline
post #2 of 13 (permalink) Old 01-27-2013, 06:56 AM
Welcome to the forum, Jim.
I feel that you may need an inlay kit to get a perfect fit.
MLCS router inlay set
There may also be other ways to achieve what you are after.
Sydney, Australia
jw2170 is offline
post #3 of 13 (permalink) Old 01-27-2013, 08:48 AM
First Name: Mark
I have an idea of what you are doing and I think there are a couple ways to accomplish this but without seeing the piece it is hard to make a complete suggestion without guessing. Is there anyway to show a picture of it?
Mark55 is offline
post #4 of 13 (permalink) Old 01-27-2013, 10:28 AM
JCJCJC's Avatar
Country: Ireland
I rout various shaped recesses regularly when making guitars (pic), once you get used to it it's easy, reliable and very satisfying. Essentially you make a rectangular template and rout inside it, either with a bushing on your router, or with a top-bearing cutter. There's a bit of calculation needed to arrive at the 'offset' - ie the template needs to be a little bigger than the recess you want to create. It will depend on your bushing and cutter combination - try several practise cuts on scrap before attacking your project. The corners of the recess will have radii corresponding to the cutter radius, you'll have to decide to either round the corners of your patch or square the corners of the recess. You have an advantage inasmuch as you can trim your patch to the recess, rather than trying to create an accurate recess to fit a manufactured item.
Practise it, it's not all that difficult. Norm Abrams has shown the technique on his shows, he calls the patch a 'dutchman'.
JCJCJC is offline
post #5 of 13 (permalink) Old 01-27-2013, 11:06 AM
Jim, this type of repair will be very tough. The reason is trying to hide the cross grain butt joint. It will be highly visible like in the photo John posted. It would be easiest and cheapest to replace the entire length of the damaged section. The repair can be done and invisible if you are willing to shell out the money for the required supplies. It really depends on the project.
post #6 of 13 (permalink) Old 01-27-2013, 01:55 PM Thread Starter
I am in luck here because I will be refinishing the piece after and it has a shaded edge going to an opaque color on the actual side. So the paint will completely hide the end grain.
This is pretty much what I had in mind. I am experienced at routing guitars with the usual bearing guides and acrylic templates.The idea was to create the patch with square corners (I have a corner chisel). Lay the patch in place and but 3 large pieces of acrylic template stock against the 3 sides of the patch and double stick tape them down and use that as my guide. But the offset makes sense. I have to figure that out. The radius at the top of the edges is what I want to reduce as well. What bit will create the sharpest edge?
The end result just has to have the tightest seams possibles viewable from the top.
jimshine is offline
post #7 of 13 (permalink) Old 01-27-2013, 02:22 PM
http://www.routerforums.com/email-ro...r-chipout.html
post #8 of 13 (permalink) Old 01-27-2013, 02:50 PM
JCJCJC's Avatar
Country: Ireland
Hey Jim - first of all, my pic was a guitar in course of construction, just to make the point - it is nowhere near the finished standard which will be a hell of a lot better, I spend months on each guitar getting details right.
The offfset issue arises if you use a bushing, it's logical and easy to calculate it. Once you know what size rectangular hole you need, you make the template. I find the easiest way to make an accurate rectangular-hole template is to run a strip through the table saw, set to the short side of the rectangle. Chop that strip with an accurate chop-saw, space the two cut ends apart the length of the long side, and glue additional strips on either side. I use scraps of laminate flooring for those, and I get to within 0.5mm of the size I want usually, at the initial stage. I use masking tape to fine-tune the template down to the final dimension.
The radius at the corners is governed by your cutter - you do a trade-off between fast removal of material and small radius. A planing or bottom-cleaning bit will cut quickly and leave a clean flat surface on the floor of your routed area.
JCJCJC is offline
post #9 of 13 (permalink) Old 01-27-2013, 06:40 PM Thread Starter
Sorry if I came off as judging your guitar. That wasn't at all what I had in mind. I was just clarifying what my goal is. The timing makes it seem like that.
Now that is a bit I have to investigate! Thanks!
jimshine is offline
post #10 of 13 (permalink) Old 01-28-2013, 03:15 AM
JCJCJC's Avatar
Country: Ireland
I get bits from George Hsu <george_4807@yahoo.com> on Ebay, if you email him he'll list whatever you want on a buy-it-now basis, I have always found him 100% to deal with. I use those bottom-cleaning bits for the pickup routs, neck pockets and control cavities on my guitars, so you'll get more than one project from them.
JCJCJC is offline
Human Verification
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
A routing tutorial for beginners Part Four harrysin Guide Bushings and Templates 23 04-21-2013 10:31 AM
Routing recess for mirror. Ski Jig? doomi Jigs and Fixtures 3 01-04-2013 06:42 PM
CNC routing as first routing experience ianthehenry CNC Routing 23 04-25-2012 05:24 AM
JIGS CAN MAKE ROUTING SAFER!! (lesson learned for a newbie) metzgeri Jigs and Fixtures 44 01-25-2011 12:00 PM
