| | #1 |
| Registered User Forum King | Don’t throw them away yet.. I found a new use for dull bits. They are perfect for cutting UHMW and other plastics. Give it a try |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Router Do you bungee jump by chance ![]() Dull bits are dangerous, they make bits for plastic and UHMW, they are made so they don't cut out as much stock in one pass but they are very sharp and don't gull up with stock the norm, some have a oversize flute/furrow/helical grooves the norm is just one.Some don't have flutes at all, they look like a steel deburing bits, the ones you can use in hand grinders air & elec.sometimes called die grinders,deburing tools. "It's fine to disagree with other members as long as you respect their opinions." MIKE Senior Moderator Bj ![]()
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 03-06-2007 at 10:48 AM. |
| | #3 |
| Senior Moderator Supreme Forum King | Router, Dull bits should not be used, they are not safe. Machine shops can often resharpen them for less than the cost of replacing them. If the bits are out of tolerance and cant be reused keep them in coffee cans; one for high speed steel and one for carbide. Both of these materials can be recycled and you can put some cash back into your pockets. (Don't expect to see much from HSS but carbide may surprise you)
__________________ Mike |
| | #4 | ||
| Registered User Forum King | Quote:
Ha, If I was any taller than 5'8" , I would get dizzy Quote:
| Magnate Router bits | kp91 | Tool Reviews | 2 | 07-09-2007 03:36 AM |
| Quality bits | RobertJR | General Routing | 5 | 04-19-2006 12:36 AM |
| Need help deciding on bits. | ryan.s | General Routing | 8 | 03-25-2005 09:35 PM |
| Dull router bits | dustmaster | Tools and Woodworking | 1 | 12-14-2004 03:41 PM |
| sharpening bits..... | reible | General Routing | 4 | 09-19-2004 09:34 AM |
