| This is a discussion on Bits for the Oak Park raised panel system within the Router Bits - Types and Usage forums, part of the Routers category; There are many manufacturers of bits. They often use the same specifications for diameters and ... |
| | #11 (permalink) | ||
| Retired Moderator ![]() |
There are many manufacturers of bits. They often use the same specifications for diameters and bearings but not all the time. When the original bits were no longer available Rick went searching and decided that the Freud bits were the best replacement and suggests them to anyone who purchases the raised panel system. I believe this decision was based on cost and availability. Once you get your catalog from Freud you are more than welcome to cross check them against other brands and post any additional sets that will work. Odds are other companies will have them available too. Since you are experienced in specifying this should be a piece of cake for you. I am not retired and between forum duties and paying the bills my days are full. If I seemed short with my responses please understand that I attended my best friends funeral today and I am not my usual smiling self. It has been a bad week for me.
__________________ Mike Please edit your profile with a name and location so we can better assist you. Last edited by Mike; 09-12-2007 at 12:28 PM. | ||
| | #12 (permalink) | ||
Sorry to hear that Mike. Corey | ||
| | #13 (permalink) | ||
| Registered User ![]() |
Sorry to hear you're going through a rough time Mike. I hope you will have better days ahead. I sincerely appreciate any help you and others give to me and each other. I think that's what this forum is all about. Rich | ||
| | #14 (permalink) | ||
I have the Freud 99-261 and am using the Oak Park raised panel jig and they work great. Plus, I find that the design of the bead actually looks better than the 2 in 1 bit OP use to carry. What I'm wondering though is why can't we use a panel cutting bit with a cutter greater than 3"? I understand the need for a 1/2" bearing, because the bearing needs to be at a certain distance in relation to the fence, but can someone explaoin to me the reasoning for the cutter? Is it just because of the hole in the fence? If I were to get one of those 3 1/8" Freud panel bit with a back cutter and simply made the hole in my fence bigger, would I be able to use this bit with the raised panel assembly? | ||
| | #15 (permalink) | ||
| Registered User ![]() Join Date: May 2006 Location: West Central Illinois "Forgotonia"; town of 20,000 80 miles from Peoria, Quad Cities, Springfield First Name: Tom Posts: 416 ![]() |
The problem is the opening in the base plate. I have been contemplating widening the opening so tha it is large enough to take the MLCS 3 7/8 inch rings. I am going to try to get the MLCS stacked rail and stile bits to work. As you can see I have plans but there will be no action until it warms up. Best of Luck | ||
| | #16 (permalink) | ||
I have bought Freud bit for the longest time but have talked to some contractors that CMT bits are execellent. Lee Valley are suppose to be putting out some good bits. There are other Copamies that are trying to upgard Your comments please Carvertst | ||
| Outlook Express problems | BrianS | Lobby | 6 | 01-06-2008 07:23 AM |
| Oak Park Raised Panel Jig.... | tpyke | Table-mounted Routing | 8 | 12-06-2007 11:43 AM |
| Those of you who have the Oak Park Panel System: | Mossy Oak | Jigs and Fixtures | 1 | 02-14-2007 08:08 PM |
| Question about raised panel router bits | LBrandt | Table-mounted Routing | 2 | 07-08-2006 09:47 AM |
| Raised Panel Router Bits | Dan Butler | Tools and Woodworking | 3 | 11-20-2004 12:30 PM |
