| Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks. |
| | #1 |
| Senior Moderator Supreme Forum King | The 3 wing bits for the Oak Park panel raising system are no longer available. The jig will only function properly with certain sized bits. Here are the numbers of Freud bits that will work correctly with the system: #99-264 #99-261 #99-263
| | #2 |
| Registered User Dedicated Member | I guess I can forget purchasing the Oak Park panel raising system since there are no longer approved bits...I see 5 of the stacked stile and rail bits available from MLCS, but am fearful of purchasing any of them as they may not be useable. If I could be sure of a raised panel bit and a stacked stile and rail bit would work, then it would be worth my while |
| | #3 |
| Senior Moderator Supreme Forum King | No longer approved bits? For your peace of mind these Freud bit numbers were supplied by Oak Park. They are approved. Any bits matching all of their dimensions will work. I thought I stated clearly that those Freud bits were the ones to use with the system.
__________________ Mike Please edit your profile with a name and location so we can better assist you. Last edited by Mike; 09-10-2007 at 01:39 AM. |
| | #4 |
| Registered User Dedicated Member | I cannot find a Freud catalg. Can you help? I want the stacked rail and stile bit as originally offered, not a two bit system... When I just asked Oak-Park about whether or not they had checked out the MLCS bits, I was told they were revamping the system to accept other bits, but not any time soon. |
| | #5 |
| Registered User Forum Geek | Hi, the raised panel bits used with the Oak-Park system are made to the same set up as bits by Freud, MLCS, and CMT. If the bit has a 1/2" bearing on the top it is on the same set up. I have used other bit sets with the Oak-Park system with no problem. However, if you use some one elses stile and rail bits you could have a problem, because the single cutter used to make the with the Oak Park system is made so that which ever one you are cutting has the face down. This was done to eliminate unevenness of thre face side which would reqiire sanding. I believe that Infinity has both cutters on one bit and it references the face side. If you buy a separate stile and rail set with two cutters just be sure that the cutting is being done with the face side to the table. That way you will have fewer poblems. On the tape that I got with the raised panel system Bob goes into the same details about having the face side down. Hope this helps out..Woodnut65 |
| | #6 |
| Senior Moderator Supreme Forum King | Dadsalmon, The easiest way to get a Freud catalog is to PM member Charles M (who works for Freud.) If you have your heart set on getting the original bit PM member BrianS. Brian's buddy has one for sale and he can help you with the deal.
__________________ Mike Please edit your profile with a name and location so we can better assist you. Last edited by Mike; 09-12-2007 at 01:29 PM. |
| | #7 |
| Registered User Dedicated Member | Thanks for the info Woody, but without exact specifications it is difficult to make comparisons between the different bits. As a former senior buyer for UPS electronics I am very cautious about specifications, and most catalogs and Oak Park do not provide enough to make absolutely certain. When you are retired on a limited income you can't afford to make mistakes. I can't see any bearings to the top of these bits either. |
| | #8 | |
| Registered User Forum Fanatic | Quote:
| | #9 |
| Senior Moderator Supreme Forum King | When I made this posting it was not intended to be a debating society. Wendy at Oak Park told me these Freud bits were the recomended replacements for the original cutter. It just does not get any simpler than that.
__________________ Mike Please edit your profile with a name and location so we can better assist you. Last edited by Mike; 09-12-2007 at 01:30 PM. |
| | #10 |
| Registered User Dedicated Member | I wasn't aware of a debate Mike. I appreciated your input, there is no need to be disgruntled. This is a forum, and as such, a provider of information. It is not a place for trained white rats. |
| Outlook Express problems | BrianS | Lobby | 6 | 01-06-2008 08:23 AM |
| Oak Park Raised Panel Jig.... | tpyke | Table-mounted Routing | 8 | 12-06-2007 12:43 PM |
| Those of you who have the Oak Park Panel System: | Mossy Oak | Jigs and Fixtures | 1 | 02-14-2007 09:08 PM |
| Question about raised panel router bits | LBrandt | Table-mounted Routing | 2 | 07-08-2006 10:47 AM |
| Raised Panel Router Bits | Dan Butler | Tools and Woodworking | 3 | 11-20-2004 01:30 PM |
