Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 05-20-2007, 06:52 PM   #1
lablover
Forum Fanatic
lablover is on a distinguished road
Default Shaker style doors
Looking to do some shaker style cabinet doors. I have the CMT matched t&G set..my question is I have seen some panel doors that have a slight bevel on the inside of the rail and styles. But are still tongue and groove with 1/4" panel. I have yet to find a set that does this. What am I missing
Thanks in advance
Joe
lablover is offline   Top - Reply with Quote
Old 05-20-2007, 07:09 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Joe if your set makes a plain square inside edge I would think all you would need to do is use a chamfer bit on each piece prior to assembly.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 05-20-2007, 07:16 PM   #3
lablover
Forum Fanatic
I hought this as well..But then the cope cut on the rail would look funny..I think Sommerfeld carries a set with or without the panel raiser.
Old 05-20-2007, 08:54 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi lablover
Most Shaker style cabinet doors are sq.cut and must be so they fit at the joints BUT you can put a slight bevel on the door AFTER the door is gluged up or just a CLAMP up with a bit(s) like below.
http://www.mlcswoodworking.com/shops.../bt_chamf.html
http://www.sommerfeldtools.com/list.asp?d=27&p=1
http://woodworkersworld.net/laminate_trim_bits.shtml
Or You can use this type of bit BUT you will have a chamfer in the joint and I'm sure you don't want that.
http://cgi.ebay.com/2-pc-1-2-SH-V-Jo...QQcmdZViewItem
You can also use this type of bit to make Shaker doors
http://www.grizzly.com/products/c1653
http://www.grizzly.com/catalog/2007/Main/485
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-20-2007, 09:21 PM   #5
challagan
Supreme Forum King
challagan's Avatar
That's right, sorry forgot if you did the whole piece before assembly you would have a chamfer the whole length of the rail and style. Bj's method would work.
Old 05-20-2007, 10:27 PM   #6
lablover
Forum Fanatic
WOW..I appreciate all the help.
I can't seem to post a link but I found a set on the sommerfeld site..The model number is 03005 and it will also work with not using the panel raising bit. Looks like I can get just the rail and style set with no panel raiser bit and use 1/4" panels.
If someone can verify that set for me it would be great.
Again..Thanks a ton for al the help
Joe
Old 05-20-2007, 10:54 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
That's the one, BUT that little taper will cost you about 100.oo dollars use your head on this one.... and cut a corner or two so to speak....
http://www.sommerfeldtools.com/item....03005&d=78&b=2
with the T & G set you now have and the bit below you can have it done.
#5379 22 1/2 deg.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-21-2007, 08:02 PM   #8
lablover
Forum Fanatic
Thanks Bob..Think I'll go your route
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 11 11-13-2008 06:26 PM
panel doors actual photo of different profiles sammy57 Router Bits - Types and Usage 4 03-11-2008 06:15 PM
We produce 400 passage doors per month. Thoughts on using CNC machine? Rmarsh Introductions 5 02-22-2008 10:21 AM
Reproducing a panel moulding on existing doors paulcomi Table-mounted Routing 3 06-29-2007 01:35 PM
Garage doors mailee Show N' Tell 5 06-05-2007 10:27 PM
