Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 05-22-2007, 10:53 AM   #1
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Default Rail & Stile 1/4" shank?
Any good recommendations for a rail & stile bit with a 1/4" shank?
(or warnings about ones to avoid)
YES - I know the BEST thing to do would be to FIRST invest in a 1/2" shank router -- but right now that's not an option.
MAYBE if I am real good Santy will bring me one for Christmas --
But I have a couple of projects this summer that would greatly benefit from
having such a bit now.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 05-22-2007, 11:16 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Cowboy
Here's one or two links, I have used the ones from the ebay links and they ARE GREAT bits.
http://www.mlcswoodworking.com/shops.../setrais1.html
http://cgi.ebay.com/2-pc-1-4-SH-Ogee...QQcmdZViewItem
http://cgi.ebay.com/1-pc-1-4-Shank-R...QQcmdZViewItem
NOTE**** if you get the one off ebay besure to print out the web page it will help you setup the bit...
One more NOTE****the set from ebay is a great set to make small cabinet doors/full glass panel doors , most 1/4" routers can take them on BUT the panel cutter may take a pass or two to get the job done.
They are smaller than the norm (2" dia. the norm is 3 1/2") but you are still removing alot of stock.
Just use the fence on the router table to take a smaller cut on the 1st and 2nd pass the 3rd pass will give you a nice clean cut.
Hope this helps a bit.
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-22-2007, 11:55 AM   #3
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
I'm sure others with more experience in this will chime in shortly, but one thing that was stressed to me when I considered this very thing is the relatively low power of a 1/4" shank router, and the size of the rail and stile bit. That is a large cutter to be turning on a small shank. It takes a lot of power to drive a bit that size, and with a large bit you must slow it down, which costs power on a small router.
You can make them with a table saw, as indicated in the following links:
Raised panels on a tablesaw
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 05-22-2007, 01:37 PM   #4
Drugstore Cowboy
Forum Geek
Brian
The first link is pretty much what I have always done in the past - making simple square rails and stiles - then adding molding to get the bead effect. I've also routed the bead on the edge then mitered JUST the bead.
I only recently discovered the specialized bits and was interested in doing it the 'right' way.
The second link has some REALLY interesting content.
Being a bonafide redneck I've done a LOT of different things with Bondo over the years (keep a can right next to my WD40 and duct tape) but I had never thought of making a shaped sanding block with it.
Definitely gonna have to print that one out and give it a good thorough read.
THANKS
Old 05-22-2007, 07:24 PM   #5
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Cowboy the only one I have is a 1/4 shank set from Eagle America. I made some doors with it and used a 1 1/2 horse power router..... the only router I had at the time. The set worked fine with a variable speed controller to slow it down which you MUST do. The router table I had at the time was a piece of crap! You can do it if you don't need to make a bunch of doors. If you do, you would be better off getting a 1/2 collet router and more HP.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 05-24-2007, 12:14 AM   #6
Drugstore Cowboy
Forum Geek
Default Logic wins out
If I stumble across a price I just can't resist - I may still try one.
But you have just about convinced me --
Thinking for now I will stick to my old way of doing them and incorprate some ideas from Brian's links.
Save my cash to put toward a good strong 1/2" collet router. Just in case Santa doesn't think I've been good enough.
Thanks for saving me from myself.
Hi all -- rail and stile bit and 1/2" collet help! Bryan Introductions 14 11-26-2007 12:40 AM
Stile & Rail Bit DougO Router Bits - Types and Usage 7 07-11-2007 09:42 PM
Rail & Stile Dilemna sameerallidina@shaw.ca Table-mounted Routing 3 01-22-2007 03:49 PM
Rail and Stile alignment....HELP arkwood Router Bits - Types and Usage 8 01-10-2007 12:07 PM
Stile and Rail setup? fitz Jigs and Fixtures 1 03-26-2005 08:53 AM
