Go Back   Router Forums > Routers > Router Bits - Types and Usage
Rate This Thread - Removing bearing?.
Thread Tools Display Modes
Old 06-23-2007, 11:36 AM   #1
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Question Removing bearing?
I find myself needing (wanting) to cut a bead on a piece of trim already in place.
Problem is -- the thickness of the trim does not allow for the bearing and screw.
I can take the bearing off - and use an edge guide on the router instead.
Any reason I shouldn't do this? Any problems I should be aware of in using a bit that came with a bearing -- with the bearing removed?
The bit in question is a Rockler 5/16" beading bit.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 06-23-2007, 12:23 PM   #2
RustyW
Forum Geek
RustyW's Avatar
RustyW is on a distinguished road
Hi Cowboy, I've never done it but. I have a Pat Warner dvd where he states that you should always remove the bearing when it's not needed to make the cut. Due to the short working life of the bearings.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
Old 06-23-2007, 01:32 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Cowboy
The bearings on bits are put on for a fence/guide so to speak, you don't need to use them if you use a fence on the router table or the plunge router,most of the time when you use a router table fence the bearing is in the ZERO place (isolated) that's to say all you are using the bearing for is a way to set the bit true to the fence..
By the way you can do this (isolate) the bearing and setup the bit up then remove the bearing from the bit from the top side of the router table BUT you must take care NOT to drop the screw or the nut, what I do sometimes is put in a rag around the bit then remove it, the best way is remove it and sit it to one side until you have the pass done,,,you don't want it to come off (unscrewed or drop off) when you are making the pass.
bobj3 is online now   Top - Reply with Quote
Old 06-23-2007, 03:05 PM   #4
Drugstore Cowboy
Forum Geek
Thanks guys
I couldnt think of any reason this should be a problem --
But any idea I have before coffee - is always subject to question.
New Guy with Bearing Bit question FREUD nicksorenson Router Bits - Types and Usage 13 06-05-2008 04:48 PM
Top bearing sliding up shaft MisterHeavy Router Bits - Types and Usage 3 04-28-2008 02:02 AM
Is my bit dull? tpyke Router Bits - Types and Usage 5 03-23-2008 09:24 AM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 2 10-22-2005 06:41 AM
