Go Back   Router Forums > Routers > Router Bits - Types and Usage
Thread Tools Display Modes
Old 07-06-2007, 12:17 PM   #1
imrichb
New Member
imrichb's Avatar
imrichb is on a distinguished road
Question Groove in edge of curved piece
I'm trying to cut a semi-circular groove along the edge of a piece, pictured in the attached. I can do this easily along a straight edge using my router table and a round nose bit. The challenge is that I'd like to do this along an edge that is curved (and to make it more challenging, a concave curve).
Any advice? I had thought maybe I could use a 3/4" ball cutter bit with a 1/2" bearing around the shank to guide it along the edge of the workpiece, but unfortunately I can only find a ball cutter bit of that size with a 1/2" shank, meaning that I can't put a bearing around it.
(In case you're curious, this is for a children's toy I am working on. The groove will essentially form a track for a marble to run down.)
Thanks in advance!
Rich
imrichb is offline   Top - Reply with Quote
Old 07-06-2007, 12:40 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
You need to make a template from 1/4" hardboard or plastic, some people prefer using 1/2" MDF. Attach it to your wood with double sided carpet tape or build a jig with hold down clamps. A guide bushing installed in your routers base plate will follow your template and a thumbnail bit should give you the profile you want.
Old 07-06-2007, 01:33 PM   #3
kp91
Forum King
kp91's Avatar
Heres a couple of options
You could play with the bearing diameters to adjust your cut if desired.
http://magnate.net/index.cfm?event=s...roup&theID=114
http://magnate.net/index.cfm?event=s...roup&theID=158
I can confidently recommend the Magnate bits.
1 John 1:9
Old 07-06-2007, 01:41 PM   #4
imrichb
New Member
imrichb's Avatar
Perfect! That's exactly the bit that I had visualized in my mind for this, but couldn't find something like it anywhere.
Thanks for the help,
Rich
Old 07-06-2007, 01:43 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Rich
The bearing on router bits,,, it's just fence so to speak, that said, make a fence like the one below, this will work a guard and let do your concave curve pass easy and safe...just ease into the bit and once your on push your stock around the guide...the guide will act like a start pin and let you get on the bit
safe and let stay ,hardwood be best for the guide/jig but it can be plywood or MDF....
The bits below also work great for what you want to do...
Making toys
Train Track Router Bits
http://www.mlcswoodworking.com/shops...ack_bit_anchor
Thanks in advance!
Rich
Bj
Old 07-06-2007, 02:03 PM   #6
imrichb
New Member
imrichb's Avatar
I like that solution as well!
Thanks,
Rich
"S" curved Routing. wildhorse General Routing 24 06-08-2008 06:28 PM
Make a template to create a filler piece? Ric Naff Jigs and Fixtures 3 01-12-2006 07:56 PM
Inserting a dado at a set distance from the edge of a curved surface Woodentop General Routing 4 11-20-2005 05:05 AM
Curved Groove Routing ? Jackalope Jigs and Fixtures 4 03-10-2005 03:29 PM
Forgot a groove - now what? Scotty General Routing 9 10-23-2004 02:35 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
