Go Back   Router Forums > Routers > Router Bits - Types and Usage
Router Bits - Types and Usage Discussion area for the wide variety of router bits available today. Get help with the selecting the proper bit for your project, usage, set up and other tips and tricks.
Thread Tools Display Modes
Old 07-14-2007, 07:42 AM   #1
Woodworker 52
New Member
Woodworker 52 is on a distinguished road
Default Mortising bit
I am a first time user of a router, I need to cut a mortise which will be 1" deep and 3/8" wide, what bit should I use?
Thank you
Dennis
Woodworker 52 is offline   Top - Reply with Quote
Old 07-14-2007, 07:55 AM   #2
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
Use a 3/8" mortising bit..
http://www.mlcswoodworking.com/shops.../bt_strai.html
Don't take more than 1/4" off at a time..
AxlMyk is offline   Top - Reply with Quote
Old 07-14-2007, 10:16 AM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Woodworker 52
I would recommend the bits listed below ,,,because the standard Straight Router Bits are Not made to PLUNGE in to the stock... they will cut well but it takes a bit of work to get them to plunge in...a rock and roll thing to get them to dig in...
Mortising is one of the hardest jobs for the router because it's hard for the bit to get the chips out of the way, it wants to recut them over and over and gets the bit hot...once it gets hot it will fail in a short time...the bit has a paper thin cutting edge and once it's gone that's it will burn the stock and you just made a new door stop out of good router bit.
Plunge Cutting Straight Router Bits
http://www.mlcswoodworking.com/shops.../bt_plung.html
OR on the higher end of bits ▼ Spiral bits will last longer and stay sharper
Spiral Upcut and Downcut Router Bits
http://www.mlcswoodworking.com/shops.../bt_solid.html
Thank you
Dennis
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-14-2007, 03:50 PM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi, I use a 3/8" spiral spiral straight bit. I cut a one inch deep mortice in 3-4 passes,
taking about 1/4" each time. Hope this helps. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Need help mortising hinges johnt Guide Bushings and Templates 11 04-27-2008 11:42 AM
Mortising Jig bobj3 Jigs and Fixtures 5 12-25-2007 01:42 PM
Mortising with the router pirtusudiculu Introductions 2 12-14-2007 01:54 AM
Hinge mortising bit and straight bit. -Sam- General Routing 1 03-29-2006 12:58 PM
