Go Back   Router Forums > Routers > Router Bits - Types and Usage
Thread Tools Display Modes
Old 07-25-2007, 11:07 AM   #1
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Question Flush Trim Bit?
Hi guys & gals,
Well here I am with another bit (no pun intended) of confusion. I had ordered a 1/4" flush trim bit with bearing attached. I decided, for some unknown reason, to put my micrometer on the bit. Here is what I found. The shaft measured .250 (14"), so far so good. The shaft that the cutters are on measured .236 (no big deal). The distance across the cutters measured .270 (should that not be .250?). No comes the kicker, the dearing diameter measured .275 (17/64"). Am I being rediculously concerned that with a bearing diameter larger than the cutter diameter I am not going to get a true flush trim following a pattern. I know, I know, wood is wood and not metal.
JoeZ
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 07-25-2007, 01:21 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
Because it's not a slotting bit that can be true, the bearing on the bit is the key....
You may want to check it one more time,, a quick way is chuck up the bit and make a pass or two...and if it does the job your good to go.... .005 is the standard for many router bits/bearings.....the .005 will change as the bit spins so to speak...point A to point B....thing...
Bj
Bj
Old 07-26-2007, 06:31 AM   #3
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
JoeZ,
It is sometimes difficult to get an accurate reading of the cutter diameter but as long as the cutter and bearing are concentric the 0.005" difference (which would only be 0.0025" on each side) shouldn't be a problem. If the bearing was smaller than the cutter you would have an issue. Also, just to note that the bit must actually be 7mm instead of 1/4" (6.35mm). What is the brand?
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 07-26-2007, 12:02 PM   #4
cbsjoez1935
Forum Fanatic
BobJ and Charles,
Thank you guys for getting back with that information. I may just be nit-picking where it is not necessary. Charles, my mic measures thousands, not mm, but coverting the measurement I made, .270 comes out around 6.9mm (close to the 7mm you recommended) so I should be OK. I have no idea of the brand since it was purchased from MLCS and those are usually Asian imports. These are my starter bits and I have had no problem with any of them. I was just curious about the measurements. Thanks again for you responses.
JoeZ
Old 07-27-2007, 10:07 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome JoeZ for my small part
Bj
Bj
Old 07-28-2007, 11:35 AM   #6
awh
Member
awh is on a distinguished road
Originally Posted by cbsjoez1935
Hi guys & gals,
The actual diameter of a flush trim bit has no affect on its usage. The difference between the cutter and bearing is only 0.005" - that seems like it would be well within any manufactures tolerances.
Happy Woodworking!
Tony
awh is offline   Top - Reply with Quote
Flush trim bit not flush RuggerJoe Router Bits - Types and Usage 8 03-19-2008 12:57 PM
Flush trim bits Hamlin Router Bits - Types and Usage 4 12-01-2007 01:51 PM
Flush trim bits boxer Router Bits - Types and Usage 6 10-31-2007 10:34 AM
Where to get a flush trim bit? wanart Router Bits - Types and Usage 4 10-28-2006 08:39 AM
Flush Trim Bit odamsr General Routing 3 09-14-2005 06:32 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
